Late fall of idling 306
08.05.2020 17:39 # 1
maykil20
Hello everyone, I just joined you
306 griffe I bought 99 new vehicles.
but I have a problem. > but when it gases, engine speed decreases from 4000 to 2000 circuit & nbsp; Waiting for 7 seconds in 2000 & nbsp;
then falls to normal idle speed.
is doing the same when going on this road. >
I went to the tuber & nbsp;
told me that it was due to the idle engine. > Reviews
08.05.2020 17:39 # 2
rolandgarros
I have almost the same problem, I think I will give the throat butterfly to clean the idle engine or something, and if I do not try my luck tomorrow, I think it will be necessary to buy new parts.
08.05.2020 17:39 # 3
ErolSs
the same problem is in me, every master I go to says normal I couldn't make sense
08.05.2020 17:39 # 4
kirmizi306
The brothers had the same problem from the same car.
They called the idler engine whichever master you went to.
cleaned a lot of trinkets nothing changed.
The idle car's idle engine is 650 million.
But when I connect it to the computer, the temperature they said it was due to the malfunction malfunction and it changed when the customer changed it. 50 tl original :) :) 2013-06-06 15:02:32
08.05.2020 17:39 # 5
rolandgarros
very good if the job was improved with the fever. Thumbs Up I couldn't overcome this problem.
08.05.2020 17:39 # 6
rolandgarros
[QUOTE = red306] Brother had the same problem with me from the same car.
Whatever master you went to, they said the idle engine.
they cleaned a lot of trinkets, nothing changed.
But when I connected it to the computer, the heat sensor said that it was due to the malfunction and it changed when the customer changed it. 50 TL is the original :) QUOTE]
Could we wear it if we take the temperature sensor from peugeotmarket? "Smile"
08.05.2020 17:39 # 7
kirmizi306
[QUOTE = rolandgarros] is very good if the job with the temperature sensor improved "Thumbs I could not overcome this problem somehow
Brother I struggled for months, there is no place I haven't gone. Otherwise I would have wasted 650 TL.
The temperature sensor of these cars is connected to the idling engine. When it fails, the idling engine does not work properly.
< / div>
Reviews
08.05.2020 17:39 # 8
ErolSs
The idle car's idle engine is 650 million. > But when I connected it to the computer, the heat sensor said that it was due to the malfunction and it changed when the customer changed it. 50 TL is the original :) QUOTE]
my teacher, was there a problem with the heat?
08.05.2020 17:39 # 9
rolandgarros
When the vehicle starts to gas itself at idle, the temperature of the car increases. detect correct "Thumbs I hope it is very useful thanks for sharing "Thumbs
08.05.2020 17:39 # 10
kirmizi306
[QUOTE = ErolSs] [QUOTE = red306] Brother had the same problem from the same car.
They called the idler engine, whichever master you went.
cleaned a lot of trinkets, nothing has changed.
< / div>
But when I connected it to the computer, the heat sensor said it was due to the malfunction. It changed after the customer changed. 50 TL original. / div> [/ QUOTE]
There was no problem in heat. I never saw it increase. There is a green-colored sender. While waiting in red, gas itself and 4000 giants re even came out.
Don't say I don't change the idle engine without connecting it to the computer.
red306 < editDate> 2013-06-06 18:36:01
08.05.2020 17:39 # 11
kirmizi306
[QUOTE = red306] [QUOTE = ErolSs] [QUOTE = red306] Brother had the same problem with me from the same car.
Whichever master you went to, they said idle engine.
But when I connected it to the computer, the temperature of the sender said that it was due to the malfunction. don't listen to the masters. div> There was no problem in heat. I never saw it increase. There is a green sender. It changed when I changed. A raba is stuck in 2000 3000 rpm. It was falling to normal. It was even in 4000 revolutions. br>
[/ QUOTE] red red306 2013-06-06 18:35:27
08.05.2020 17:39 # 12
ErolSs
[QUOTE = red306] [QUOTE = red306] [QUOTE = ErolSs] [QUOTE = red306] Brother had the same problem from the same car.
Whichever master you went to, they called the idle engine.
Idle car's idle engine is 650 million. < / div>
. > 30 pounds, connect to the computer, keep an eye on the masters.
There was no problem in heat. I never saw it increase. There is a green colored sender. It changed when I changed. A raba is attached to the head in 2000 3000 rpm. he was staying normal after 1 minute. Ken gave himself gas and even went over 4000 cycles.
[/ QUOTE] [/ QUOTE]
my friend is fed up with the problem of idling
oxygen probe
intake manifold sensor
even the engine valves have changed, don't you tell me when it is still cold, it doesn't do much but when it gets warmer, the car finally says one of the sharp intelligence is an idler engine. 170 tl has changed to a minute, a goal is still the same problem: =) The car that burns 18 cents burns 23 cents thanks to the last care, as you said, I am waiting for your approval. I am waiting for your confirmation.)) div>
Reviews
Reviews
