lapping in the new audio system
08.05.2020 18:28 # 1
KIZILASLAN
I made a complete complete sound installation on my friends vehicle while I was browsing the nett, I heard that these systems had a running-in period in a forum, so that the system has such a running-in period for all tape amplifier speakers to get used to each other.
08.05.2020 18:28 # 2
barishrocker
Exactly. This time varies according to all equipment. Even cables have running-in. After a while, when I noticed the change in the sound, it may be necessary to adjust again. For example, my trebles started playing better than the first play. You get the zero car, they pull the adjustment at the first oil change or something like that :) you have to turn on the engine ..
08.05.2020 18:28 # 3
KIZILASLAN
So how long does this process take and how should we use the system during the break-in period?
08.05.2020 18:28 # 4
Turgay_66
I heard it for the first time Wacko
08.05.2020 18:28 # 5
barishrocker
[QUOTE = Turgay_66] heard for the first time "Wacko" [/ QUOTE]
Examine the cable burning machine or something, sir. It shortens the running-in of cables.
08.05.2020 18:28 # 6
barishrocker
[QUOTE = dehsetilyo] So how long does this process take and how should we use the system during the break-in period [/ QUOTE]
I do not know that in detail, it depends on the product, brand and model. But it may be done by finding regular music CDs and listening in low, high and medium sounds at certain intervals. This is already the detail.
I installed my system and said the first setting was done. Now it plays differently than the first system. So its running-in is full and it will be adjusted again. I will stop by if the master is available today ..
But as I said, these are not everyone knows and pays attention to detail.
08.05.2020 18:28 # 7
KIZILASLAN
How long did your system get stuck on my tape speaker 6 months old sub 2 weeks old
08.05.2020 18:28 # 8
barishrocker
Listening time is important, not time to hang out. My car is always sleeping .. If you listen for an hour every day and you feel distortion in the sound, you can make a small adjustment or even do it yourself if you understand ..
08.05.2020 18:28 # 9
KIZILASLAN
Thanks to the installers who do not understand the job and the internet, I learned this tuning work and changed the complete setup and connections of the system myself now. Now the system is playing better and stronger.
08.05.2020 18:28 # 10
barishrocker
If there is no distortion in the sound, I would say very tampering. Because there is a gain setting, you can turn it on the amp and burn the treble or something or damage the bottom.
See also the settings on the tape eq and balance, treble, bass etc.
08.05.2020 18:28 # 11
KIZILASLAN
I am already satisfied for now, I can get very nice bass sound even in very good low voices.
08.05.2020 18:28 # 12
206FR
If you do not understand that the sound system does not taste like the day it was first installed, then you go and have a setting, if you do not understand, do not damage the system by not playing with the settings of the amp.
