lambo, lsd, swing up door
08.05.2020 15:56 # 1
deamod
There are friends who make this on our friends site. Is it easy to use? Is it comfortable? What is the price?
08.05.2020 15:56 # 2
We have a friend named Aşil_16.
The room is using the same door system ..
I am sure you will get healthier information if you contact him.
08.05.2020 15:56 # 3
good morning everything is nice but it becomes almost impossible to get out of the vehicle in case of accident. The hinges that open to the side of the vehicle I know are being canceled, it seems almost impossible to open the door in the event of an accident, just because it is an upward opening. At Bursa meeting, we examined the tool of our Achilles friend and the same application is also available in him. As my colonel said, if you consult her, the pros and cons that we cannot see can tell you better.
08.05.2020 15:56 # 4
deamod
Teşekkürlerr ....
08.05.2020 15:56 # 5
He must have been a master in Inegol, he was manufacturing it. You'd better investigate it from the owner
08.05.2020 15:56 # 6
asil16
[QUOTE = AlbaYDemircaN] We Have A Friend For Achilles_16.
hello my friend, the doors were made in the light-up, they are putting the hinges on the door, and they make a cool piss by weaving a certain pattern, I do not hesitate if I want to peel the truth, because there is no use because the door does not know that the door hurts up and it will pull the door towards you there is yawning in the mudguards.
Since I was very troublesome to turn it into a old state, I am not very uncomfortable, I have heard that there are places in Bursa and Istanbul,
08.05.2020 15:56 # 7
g-demir
I know it is very expensive, I would make it stop if the price was affordable
08.05.2020 15:56 # 8
asil16
[QUOTE = g-iron] I know it's too expensive, I would make it stop if the price is affordable [/ QUOTE]
08.05.2020 15:56 # 9
musictime
If you reset it to the wall, you can not go out, if you try to go out, you draw: D or big trouble, we continue to normal: D
08.05.2020 15:56 # 10
deamod
Now I bought this hinge for a nice price. Can I do any special service, just my hinge is running out, do I need other additional parts?
08.05.2020 15:56 # 11
asil16
There is a place that imports before, happy, I think if you reside in Antalya, you can find it.
08.05.2020 15:56 # 12
this door continent is not so expensive or I saw it from its owner, it is changing between 250-500 :))
08.05.2020 15:56 # 13
g-demir
[QUOTE = 60de106] this door continent is not that expensive or I saw it from its owner I am changing between 250-500:)) [/ QUOTE]
You can find him and get him. what is it? 4500 pounds yaww!
08.05.2020 15:56 # 14
djchaos
The disadvantage of up to 4 thousand tly, the head hitting, the difficulty of opening when you park it under the low wall or under the tree or scratching while opening is not opening as some while it is hydraulically opened. I know that these are expensive ones. The view does not end hard but it is beautiful but it is difficult. The shortest example I have experienced personally. djchaos 2011-10-04 01:07:08
08.05.2020 15:56 # 15
I do not recommend it, I thought very much when we had 306 in time, and I did not investigate it, it is not healthy at all, the second wear out is very early, after a while the pressure ends, the door does not hold and you are struggling. Do not waste it, continue, do not waste money in vain ...
08.05.2020 15:56 # 16
While I was researching, it could be made between 800 and 900 liras. They disassemble the hinge.
08.05.2020 15:56 # 17
Now I let the friends know, the price comes in two days :))
08.05.2020 15:56 # 18
okan77
I had a friend who used 106 quixilverda. Remote control can be opened and closed ... Pleasant but troublesome. Mazallah like guillotine ... :)
08.05.2020 15:56 # 19
OUZHNKYA
If I ask friends who know the address or phone number of the master doing this in Istanbul, can they return to me?
08.05.2020 15:56 # 20
Turgay_66
I think it is expensive
Page : / 2
