Lacing from the front
08.05.2020 16:06 # 1
kinvan
mrb friends pejo 306 sedan has a clack that comes from the front right, especially on the bad road.
08.05.2020 16:06 # 2
droprain72
Hello friend. Call me, I had the same problem, I changed the shock absorber, it improved.
08.05.2020 16:06 # 3
kaan__
you have to change the 4 numbered parts in the picture, this sound gets more and more, zateb is not too expensive, it is said to say z rotu or z handle
"0" />
By kaanozkaplan at 2011-09-05 Reviews
08.05.2020 16:06 # 4
I think there is a shortage in the front team, I think
08.05.2020 16:06 # 5
It can also be from the shock absorber block. If there is a cover where the right shock absorber is attached, remove it and start to spring your vehicle.
08.05.2020 16:06 # 6
kinvan
Thank you for your responses front shock absorbers tie rod tie rod tie rod new shaft changed, but the sound is still the best I change the z-rod bidet die dead
08.05.2020 16:06 # 7
look at the engine ear chocks ... especially I changed the lower ear chock 2 times ... there is no problem right now ... there are 306 in me ...
08.05.2020 16:06 # 8
Also, the engine wedges of the 306s fit one to one in 106 and they are more durable than the wedges of the 106s.
08.05.2020 16:06 # 9
I think the problem is not from the shock absorber, it would not have been fooled by it. There was one more thing.
08.05.2020 16:06 # 10
Maybe there is a problem in the hood, not a problem ??
08.05.2020 16:06 # 11
speedark
I have the same problem, the shock absorber has changed, the tensioners have changed, still there is the same problem. I took it to 7 masters.
08.05.2020 16:06 # 12
It can come from everywhere, as you can understand from different comments. If you have the possibility to shoot videos, shoot videos and we can make more accurate comments.
08.05.2020 16:06 # 13
kinvan
for your help, good friends, let's have a bidet wedge or something
08.05.2020 16:06 # 14
tayfundoner
There is a piece of rubber on the bend bars in the picture above 2 & nbsp; 3 & nbsp; You need to change the number 5 parts, I think the same problem happened to us, we showed it to many masters, some of them said that the shock absorber said some of them were broken, the front team said, finally we went to our master, he made a test drive, he changed the parts 5 months ago, there is no sound from the front ...
08.05.2020 16:06 # 15
djchaos
[QUOTE = kinvan] mrb friends pejo 306 sedan has a right-sided lacquer in my car, especially when doing a lot on the rough road.
I had the same problem, lak lukur sound sounded z rotu or steep stub changed changed sound was cut off
08.05.2020 16:06 # 16
lou_blue
friends have the same voice in me but only on turns and on bad roads what could be the reason
08.05.2020 16:06 # 17
zavur
If it's not a rotten & nbsp; akis look at the ball, a world master walked me until I found this piece & nbsp;
