LAC-LAC SOUNDS FROM BACK IN 307 SW
08.05.2020 17:20 # 1
iozbudak
I APPLIED THE EXPLANATION OF THE FRIEND ON THE SITE. HOW DOES? I EXPLAINS. Look at the shock absorber from the top of the rear wheel to the fender. THE SHOCK ABSORBER HAS A PLASTIC PIECE LIKE A HAT. YOU WILL FIND IT BY HAND. IT'S A PART THAT MOVES UP AND DOWN. IF IT IS FOUND, DOWNLOAD THIS PIECE ABOVE AND GET THROUGH JAPANESE ADHESIVE FROM AROUND 3-4. DRY'S SOUND IS OVER THE PROBLEM. MULTI-LOADED OR SET CAN BE REMOVED FROM THE POINT WHEN IT ENTERED A KASIS. REFRESH THE PROCESS.
