Kut kut ses in automatic gearbox
08.05.2020 20:02 # 1
soner09
Hello, my newly bought 407 cars will sound officially in automatic gear shifts, but this only happens when the car is warming, for example, the car has stopped, I put it in reverse, the car is waiting for 1 or 2 seconds. but I always have a car help please help with knowledge
08.05.2020 20:02 # 2
talip206
There may be a problem with the shift position switch. But start with the brake sensor first. These kinds of situations can happen when the brake sensor is faulty. 20 30 tl a piece but replace with the original.
08.05.2020 20:02 # 3
soner09
But here is the problem, when the car is cold, there is a problem when the car gets hot.
08.05.2020 20:02 # 4
As it is related to the shampoo oil silencer, you can come across with such problems when my coach is not cool enough.
08.05.2020 20:02 # 5
soner09
the solution is to change the coolant
08.05.2020 20:02 # 6
If I say change it directly, I would be misleading. If my engine and the gearbox are hot, a good gearboxer will fail to connect with a master computer. The car will look at the gearbox oil temperature and pressure. It should not be done without checking. Do you know when the gearbox and filter of the vehicle last changed?
08.05.2020 20:02 # 7
soner09
I bought walla vehicle, I changed the oil in France, the filters have changed, the gearbox oil has not changed, let me change it first.
08.05.2020 20:02 # 8
Soner my name before changing the oil, you can have it connected to a computer when the engine is hot, check it, then the problem comes out of the solenoid valves, again the gearbox oil etc. don't pay
08.05.2020 20:02 # 9
soner09
okay tmederm
08.05.2020 20:02 # 10
I would like to ask you to change my brother's brake sensor without forgetting it, around 15-20 TL, even that original piece can cause such problems.
