Kornaaa to
08.05.2020 16:45 # 1
serhat.307
Guys, I don't understand the horn of this car. The horn does not work. But the horn sounded a few times, but still fell silent. what should I do. I tried to open the left windshield at once, it did not open. I tried to close it when it was opened. It was not closed. When the glass is half open sometimes I open it completely. I want to close it completely. he did this once, but from what?
08.05.2020 16:45 # 2
serhat.307
Is there anybody who gives no idea?
08.05.2020 16:45 # 3
ismailkaya
slm i am from bursa ismail
serhat bey first let's solve the problem of your horn, i think there is a problem in the connection socket of the horn, there is a stone crash or your car crashed from the left side, I don't know how to look at the horn that will be in front of the left wheel, but the horn will be removed in front of the left wheel. or partially open it, check it out visually
& nbsp;
& nbsp; & nbsp; the left door window opening button is dusty, you do not need to buy a new key, find the key, remove the two & nbsp; & nbsp; socket & nbsp; Carefully remove the electronic circuit inside the fingernails, remove the cotton, then plug it in again, plug in the socket connections, and let it be easy to try.
08.05.2020 16:45 # 4
muratoner
If my friend is 307, the problem is that the horn metals under the airbag are corroding to each other. When it comes to the glass event, as the friend says, when it gets clogged, it will get better if you disassemble the yapo and spray the oil-free cleaning spray.
08.05.2020 16:45 # 5
serhat.307
Thank you friends. I will consider your suggestions.
