Knurling sound in 2nd gear
08.05.2020 19:37 # 1
medcvt
Greetings friends I'm using 106 xr 2. When installing the gear gag he b had audio sounds as if the gears have stiffness transition like I sıyırıyo Yağcı samzee bearing oil may be laid thick said black metallic powder on oil Remove discharged screw synthetic fatty laid if the problem persists further be said can be a problem What is your problem engine bay bi does not do it when it gets warmer does this problem because the weather is cold, thanks in advance Cry medcvt 2016-01-24 21:22:53
08.05.2020 19:37 # 2
medcvt
What if there is no friend to help who knows about it
08.05.2020 19:37 # 3
I think it is very stuck, my 206 is also very difficult to shift gears in the first morning, just like you said. There is no problem in the fuel situation and different noises when the vehicle is going
08.05.2020 19:37 # 4
outlaw
the first time you start the car until it warms up, because the weather is very cold, there is freezing in the transmission oil for 5-10 minutes.
otherwise you can eat synchromes.
08.05.2020 19:37 # 5
106IM
Although my friends warm up when the engine is cold, sometimes when I pull it from 1 to 2, the voice sounds from me, but thank goodness. I wonder what my synchrome shift sticks in my gear lever is. Where do I need to lubricate exactly where the gear sticks are, thanks in advance. If I do not lubricate the gear rods, I think synchromesh. It does not do in other gears, where do I need to lubricate? THE PROBLEM IS HEATING AT YOUR INFORMATION.
08.05.2020 19:37 # 6
Emre106xs
Friends related to audio gear synchromes 1 and 2. If the gear synchromes are changed, you get rid of the sound 👍
