knocking on the gas like shaft shaft
08.05.2020 16:45 # 1
inceyasar
Hello, I wonder if I was friends who had this problem.
When the car is going to pull my foot out of the gas and press the gas again, the car is knocked. The engine chocks were looked. Is there a friend who has an idea that has not been fully resolved? >
thanks
inceyasar 2012-05-08 16:35:54
08.05.2020 16:45 # 2
dukenukem82
see gears related parts & nbsp;
08.05.2020 16:45 # 3
59ice307
slm friends, I have the same problem, I can even be from the bottom wedge dye sponsorship Şahin I got the wedge from peugeot murat bey but I couldn't change it again. Meanwhile, thanks and greetings to murat ..
08.05.2020 16:45 # 4
59ice307
I would be glad if you share the result, thanks
08.05.2020 16:45 # 5
furkan
I had the same problem in my vehicle too, when I pressed or pulled the 307 throttle and pressed again, the transmission was knocking as if there was a gap in the axle shaft.
08.05.2020 16:45 # 6
inceyasar
I think the general feature of these 307s is there is no one who solves this problem?
08.05.2020 16:45 # 7
ismailkaya
& nbsp; look at the motor buckle for the tie rod end and shaft, but most likely it is due to the engine buckle, if it hits the steering, this knock rod head and shaft may be from the steering box & nbsp; ball.
08.05.2020 16:45 # 8
inceyasar
the engine chocks have been replaced with the original on the upper right, others have been checked, others do not hit the solid steering wheel, a little knock is felt when the gear is held by hand.
08.05.2020 16:45 # 9
hadem80
Friends, I have the same problem. My vehicle 2005 206 hdi sw x-lina. & Nbsp;
Previously, there was a similar situation, it was improved by changing the upper ear. But this time it is different, it sounds like it hits the shaft. In addition, the same event happens when the gas is pulled out of the gas while traveling at normal speed. The problem could not be solved. Some said axle tulip. Some wedges said. All changed and tried. But there is no solution. They said that the last axle tulip should be changed and tried, but the source does not keep order. It kept about 400 TL in zero. & Nbsp;
It is not a problem to change, but if the problem continues after changing it, the axle tulip will be changed in vain. & Nbsp;
I also need to solve the problem. If anyone has any information, please share.
08.05.2020 16:45 # 10
hadem80
How did you solve it. & Nbsp;
08.05.2020 16:45 # 11
inceyasar
The problem has not been solved. The engine chock has decreased a little. The masters & nbsp; have tried a few 307 said they were all & nbsp; but I still feel uncomfortable. other cars I use are not available & nbsp;
the problem has not been solved, but it has decreased compared to the past & nbsp;
08.05.2020 16:45 # 12
hadem80
I am disturbed in the same way. Shoots like novice drivers hit. They suspect Akis tulip, but I know the truth. I don't want to do a costly operation. & Nbsp;
08.05.2020 16:45 # 13
fatihgg
As far as I understand, I guess it hit the gas and hit it when I pulled out. If I think the novice driver bounces the car like you think it is the problem, there is a gas officer in the cars, it is tickling when you touch it.
08.05.2020 16:45 # 14
HasanD
Hello, my car is 2001 model 206 Roland Garros. I have a similar problem, but I just feel at the start and shifting to 1st and 2nd gear. I feel more in my foot especially when pulling from the clutch on start-up and pressing the gas at the same time. What could this be about? Thank you.
08.05.2020 16:45 # 15
inceyasar
[QUOTE = fatihgg]
As far as I understand, I guess when I pressed the gas and hit it when I pulled it. If it was like the novice driver bounced the car, the problem is that we have a gas officer in the cars. br>
buddy what is this gas sensor? Can you explain a little?
08.05.2020 16:45 # 16
fatihgg
Do you know the clutter officer who would be in the engines?
08.05.2020 16:45 # 17
esra_16
hello I have all the problems written here in my car since 2002 model 1.4 hd, it seems like it has been pushing the gas and pulling my foot forward, shaking the clutch and shaking it, it is like having difficulty. , the latest gearbars and gearbox chocks have changed but nothing has changed, the problem continues even worse.
08.05.2020 16:45 # 18
fatihgg
[QUOTE = esra_16] hello all the problems written here are also in my car Since 2002 model 1.4 hdu it seems like it has been pushing the gas and pulling my foot forward, it seems like it is shaking when I pull the clutch. so how many repairers have seen, the latest gearbars and gearbox shifter have changed but nothing has changed, the problem continues even worse. I went to a mechanic who passed, said that the front team had to change completely, it cost 600 TL, still couldn't decide. ? [/ QUOTE]
Do you see the gas officer, he understands the master, he does not burn the fault light, but when he connects to pp, even if you find a good knife master you got it.
08.05.2020 16:45 # 19
metin
is it only on departure? there may be a gap in the axles.
08.05.2020 16:45 # 20
inceyasar
No, it is not only on departures, it happens when we pull the foot off the gas and press it again while going on the road, and if you do not pay much attention when shifting gears.
Page : / 4
