knocked on triptronic transmission
08.05.2020 16:44 # 1
SserkanT
Hello everyone & nbsp; 2004 model 107 thousand km 307 1.6 xt premium & nbsp; & nbsp; I have a problem with the transmission of my vehicle. when I give gas to the vehicle in heavy traffic, it does not give tap & nbsp; when the speed reaches 2500 3000, & nbsp; the sound is like a shock and shake, so the temperature rises and the friends who know what I can meet before going to the service & nbsp;
08.05.2020 16:44 # 2
toga406
I understand like solenoid valves. is it true friends
08.05.2020 16:44 # 3
metin
If you replace solenoids with new types of solenoids, there is no problem. It is fixed by experience.
08.05.2020 16:44 # 4
SserkanT
It is costly to change solenoids. Do you trigger a heat this fault? thanks in advance
08.05.2020 16:44 # 5
metin
Transmission oil gets very hot in heavy traffic stop and start. In this case, solenoids cannot fulfill their duties sufficiently. The task of solenoids is to shift the gear, change gear etc. & nbsp;
normally idle oil pressure should be 2.5 bar. pressure increases as the speed increases. The solenoids also change gears by spraying oil with this pressure. that is, it cannot fulfill its low solenoid duty. & nbsp; have the tool connected to the computer. If the gearbox oil pressure is below 2.5 while the engine is hot and running at idle, you will need to replace the solenoids. they cause such problems. Then they released a new solenoid under the name brog varner to fix these problems. Those who want to have it must be the old type, the defective type. It's easy to understand that. If there is no sound called Cizzzzzz from the gearbox when you start the car and take it to D or R, it is the old type. The new ones work loudly. & Nbsp;
Last year, 2 solenoids + oil change + workmanship was around 600 TL in the authorized service. I will help if you change.
textin 2012-05-02 23:35:48
08.05.2020 16:44 # 6
SserkanT
[QUOTE = text] stop in heavy traffic, transmission oil gets very hot. In this case, solenoids cannot fulfill their duties sufficiently. the task of solenoids is to shift the vehicle, change gear etc. & nbsp;
normally idling oil pressure should be 2.5 bar. pressure increases as the speed increases. The solenoids also shift gears by spraying oil with this pressure. that is, it cannot perform solenoid duty at low speed. have the tool connected to the computer. If the gearbox oil pressure is below 2.5 while the engine is hot and running at idle, you will need to replace the solenoids. they cause such problems. Then they released a new solenoid under the name brog varner to fix these problems. Those who want to have it must be the old type, the defective type. It's easy to understand that. If there is no sound called Cizzzzzz from the gearbox when you start the car and take it to D or R, it is the old type. The new ones work loudly. & Nbsp;
Last year 2 solenoids + oil change + labor was around 600 TL at the authorized service. I will help if you change it.
There is no sound when changing gear, I think my vehicle is 2004 model old type. If it will completely eliminate the problem, let's replace the solenoids, of course. very annoying. I will take it to mapa tomorrow & nbsp; Does it indicate malfunction when connected to the computer?
08.05.2020 16:44 # 7
fTh206
Just like solenoid + valve + you will change the gearbox oil when they have changed, it is obligatory.
08.05.2020 16:44 # 8
metin
sserkant; it may not indicate malfunction, you see its parameters, pressure values etc.
08.05.2020 16:44 # 9
SserkanT
this morning I went to hunters mepa. As a result, the connection to the vehicle computer & nbsp; no problem was said, even if it was not too detailed, test drive was done. I was surprised. started knocking on the way back. I'm sending hair head right now & nbsp;
08.05.2020 16:44 # 10
foresteng.
In my car 2006 model 206 automatic 1.4 ... It started to change in my gear especially late and noticeable. In the 1st gear shift, & nbsp; is OK, but when changing from 2 to 3 or 3 to 4, the speed changes between 3500 and 4200 when the speed is between & nbsp;. In this case, the vehicle is screaming a lot.
The reason is solenoids known?
08.05.2020 16:44 # 11
fTh206
[QUOTE = foresteng.] In my car 2006 model 206 automatic 1,4 ... It started to change in my gear especially late and noticeable. In the 1st gear shift, & nbsp; is OK, but when changing from 2 to 3 or 3 to 4, the speed changes between 3500 and 4200 when the speed is between & nbsp;. In this case, the vehicle is shouting a lot.
Why is it known solenoids? Switching to `` s '' mode, this causes high speed.
08.05.2020 16:44 # 12
metin
[QUOTE = SserkanT] this morning I went to hunters mepa. As a result, the connection to the vehicle computer & nbsp; no problem was said, even if it was not too detailed, test drive was done. I was surprised. started knocking on the way back. I'm sending hair head right now & nbsp; [/ QUOTE]
may not appear in the fault log. Did you look at the transmission oil pressure when the engine was hot?
the reason for the knock was low pressure, the faulty solenoid because. & nbsp; div>
I recommend you go to peugeot berke. Find the service master ladybird there, he helps you.
08.05.2020 16:44 # 13
metin
Why are the solenoids known?
Did you check the brake sensor of the
? I handled the same problem with the brake sensor at 307.
08.05.2020 16:44 # 14
SserkanT
[QUOTE = text] [QUOTE = SserkanT] this morning I went to hunters mepa. As a result, the connection to the vehicle computer & nbsp; no problem was said, even if it was not too detailed, test drive was done. I was surprised. started knocking on the way back. I'm sending hair head right now & nbsp; [/ QUOTE]
I recommend you go to peugeot berke. find the service chief lady, there he will help you.
[/ QUOTE] I will follow your recommendation and write the result I will go to the weekend & nbsp; berke as soon as possible. thanks for your interest
08.05.2020 16:44 # 15
foresteng.
I press the gas normally, & nbsp; there is no loading. but i don't like it. Before I bought it, I had the vehicle checked at the transmission. They connected them to the computer, they said no problem. Now that is how people get bored .. & nbsp;
08.05.2020 16:44 # 16
foresteng.
I could not understand the connection with the brake sensor. Can you explain?
08.05.2020 16:44 # 17
metin
[QUOTE = foresteng.] I couldn't understand the connection with the brake sensor. Can you explain? [/ QUOTE]
I don't understand the brake sensor, but this is one of the solutions. This is how I deal with the same problem that I had. If you already review the link, there are solutions available as a list.
08.05.2020 16:44 # 18
foresteng.
[QUOTE = text] [QUOTE = foresteng.] I couldn't understand the connection with the brake sensor. Can you explain? [/ QUOTE]
Well interesting, thank you ...
08.05.2020 16:44 # 19
aacemm
I was an automatic user of 2004 307, passed by my head and solved it with brake brake, eventually. When I was driving in the lights while I was on the road, I was pressing the gas when it was burning green, but it was not moving. and I replaced the solenoid valves, the arfa was 82 thousand times. the result did not change.I thought black and started researching and finally found it.
the brake sensor was broken. There was no sound. vehicle error code also did not give up. I have spent up to 25 tl but then I solved it to 25 tl but we had to change the gearbox oil at 60 thousand, by the way we got it done.
08.05.2020 16:44 # 20
[QUOTE = aacemm] I am an automatic user of 2004 307, passed by my head and solved it with the brake sensor, eventually. I went. I changed the gearbox oil and solenoid valves, the car was at 82 thousand. the result did not change.I thought black and started researching and finally found it.
the brake sensor was broken. There was no sound. the vehicle error code was also not given. I had to pay up to 25 TL but then I had to change the transmission oil at 60 thousand but by the way we had to fix it. Meanwhile, you have to check again the brake sender
same problem in me. is on the long way. When I enter the city after a long road, it gives water well. the solenoids were changed before and I changed the gearbox oil but it did not remedy, when I connect it to the computer it shows "skid and grip" error. said service gearbox revision but i don't know what's the case. I think this tool should not work properly if there is a situation that requires revision. I changed the brake sensor myself once, as if there was no problem. it seems to me that there is a problem with the cooling of the oil because this malfunction occurs only when the vehicle gets too hot. & Nbsp; & nbsp;
Page : / 2
