knocked in automatic reverse gear
08.05.2020 18:21 # 1
yildiz
Hello everyone. We had our first peugeot car up to 3 weeks ago. 2004 model 307 xt automatic. the vehicle was good, but the peugeot's automatic transmission is like how can we trust it, we took the vehicle to the master in the industry (before buying it), let's look at the master. But it is not a problem, he said (I will not realize if he does not say man, but it is obvious that it is true). The man we bought changed the gearbox oil for this problem.
Now, if we keep driving this car with this knockback knock, would we have big trouble?
Is there no cure other than revision?
How much can we trust if we have the master revised outside the authorized service? (I live in Izmir)
Thanks in advance to all interested. Such a forum is a great boon for every user. I liked the car but this event missed some tasting Confused
08.05.2020 18:21 # 2
Serkan
Since we do not know the intensity of the knock, I will not be able to say anything exactly, but it knocks in reverse gear, I do not think there is a revision situation, if there is no situation that disturbs you in normal use, so continue riding, the vehicle will already warn you if there is a serious problem.
08.05.2020 18:21 # 3
yildiz
There is a slight imbalance at idle and a louder sound, but no trouble driving normally or driving in reverse. Is there a warning system related to the transmission when the car warns, the 2004 model 307s, an icon appears on my screen?
08.05.2020 18:21 # 4
Serkan
Yes, there is a warning system, snow and sports mode lights flash and the road computer also gives automatic gear fault warning.
08.05.2020 18:21 # 5
yildiz
thank you
08.05.2020 18:21 # 6
206cc57
Get well, it makes me feel a little knock back in gear at 206 cc.
My Vehicle 2004 206cc from time to time, dropped from the traction doing back misses. It was getting better when you run it again. After a long time, its traction dropped again and Sports snow light started flashing with Automatic gear fault warning. .. Fortunately, it returns to normal when it is run-and-run. I always go to Tuzla as an authorized service, but I do not want to get tired financially these days.
08.05.2020 18:21 # 7
yildiz
personally, I am in here, they recommend Ünal in the 2nd industry. Friends living there will help for Istanbul.
08.05.2020 18:21 # 8
slhyldz
[QUOTE = 206cc57] Get well, it makes me feel a little knock in reverse gear at 206 cc.
There are automatic gearboxes on the Bostancı industrial site. They understand it well from this vehicle and gearbox. I have a Bostancı automaticcenter, for example, I hope you will be satisfied. It scans from the internet. Oil change solenoids brain cleaning + software keeps 550 TL. They test other valves, too. If there is a broken one, 50 TL.
08.05.2020 18:21 # 9
206cc57
[QUOTE = slhyldz] [QUOTE = 206cc57] Get past, it makes me feel a slight knock in reverse gear at 206 cc.
Thank you very much, you have given the most detailed advice I have ever received, I was thinking of captain pejo in pendik, I used my car today, it did not fail but I will definitely go to the service in the week ahead. Thank you again
[/ QUOTE] [/ QUOTE]
08.05.2020 18:21 # 10
slhyldz
[QUOTE = 206cc57] [QUOTE = slhyldz] [QUOTE = 206cc57] Get past, it makes me feel a slight knock in reverse gear at 206 cc.
Captain would not recommend automotive. They don't understand it automatically. This process costs around 750 TL. The parts prices are exactly the same as those of the service. You only profit from craftsmanship. The room is nothing.
I had my car first serviced there. I love 700 TL.
(oil, filters, thermostat, spark plug, fan resistance) It was not enough my car had trouble the next day. I found another service and fixed my problems there.
[/ QUOTE] [/ QUOTE] [/ QUOTE]
08.05.2020 18:21 # 11
206cc57
Okay, as you have specified, I will go to the autocenter truckman.
It varies from fault to fault, each situation may differ from each other, but you know how long it takes to change the selonoid oil change? It may be better to call and make an appointment, because I feel knocked on uphill and steep climbs.
206cc57 2014-03-13 18:02:25
08.05.2020 18:21 # 12
slhyldz
[QUOTE = 206cc57] okay, as you have specified, I will go to the autocenter truckman.
It takes half a day. They give detailed information if you call and speak. Sold master and Nihat master. If the 206 and 307 models use the same gearbox (if you ask) 50Hz in Solenoids until 2006. New solenoids 100 hz. and it needs to throw software when it is installed. Works hard with existing software. In addition, it will introduce the transmission to the accelerator, etc. Make sure the brain is cleaned. They know, but ultimately you should be followers of your job rather than the master. Highlight these as well. Ask 3-5km when you test. Stop and force it around. Then take it. Finally, you should change the oil every 3 engine maintenance.
Good luck with.
08.05.2020 18:21 # 13
206cc57
Hi ,
I called the service you called and made an appointment, but recently I was a bit cramped in cash.
In this case, I took my credit card and went to Dumankaya peugeot where I always went. Master in the service said that the oil change is enough. My valves were doing their job.
Transmission oil change (5 lt Al4), Top cylinder head gasket change (front and rear cylinder head does not sweat any oil removed), Engine water addition, steering hydr. oil addition (my steering pump has been missing oil before), they put 40 - 50 tl of gasoline when I took the gas at my car, cleaning the waste oils in the engine and smiling and listening and seeing off.
I do not feel the shift gears in my vehicle now , it does not give error for 1 week. I paid 328 TL in total and 6 installments on credit card.
206cc57 2014-03-26 14:00:32
08.05.2020 18:21 # 14
slhyldz
[QUOTE = 206cc57] Hello,
Yes, if you had taken it to the gardener, the room would have been solid for your valves. Because they suspend one of the wheels and connect it to the device and test it in different positions. Only I did not understand the 40-50 gasoline event. Why did they fill it up and get their money from you?
08.05.2020 18:21 # 15
206cc57
I did not buy gasoline on the way to the service, it was low and the fuel low light was on, .. :(
I thought it was enough in the tests, there was a quarter tank of gas on my delivery car.
