knocked after solenoid change
08.05.2020 19:16 # 1
emreerdem78
Hello
2003 307 1.6 automatic lpgli. Two solenoid valve changes. The engine started screaming more than usual, but the traction increased. Then, in the mornings, when the engine was cold, it started to knock on the 2nd gear. Friday did not change, Monday did :) I got rid of auto fault gear you will understand. But motor shouting and 2nd gear was hit in the morning in the evening. Thanks for your help in advance
08.05.2020 19:16 # 2
talip206
The oil may be missing.
After the selenid change, the software should be updated and new solenoids should be introduced. if not, he can do it too.
The master has changed the spark plug and the coil to waste because the problem is related to the gearbox after the solenoid change.
Have the motor and transmission ears checked.
Also check your additional coolant container. If the coolant inside exceeds the max level, drain the water a little.
08.05.2020 19:16 # 3
emreerdem78
Thanks for your response. It was ridiculous to me too. But I believed it didn't hit the day it first changed :) Now I will go to discuss what you said with the master.
08.05.2020 19:16 # 4
hope you have a solution to your problem.
08.05.2020 19:16 # 5
ebay otomotiv
Hello emreerdem78 spark plug and coils have nothing to do with the knock.If your car continues knocking after the solenoid valve, the gearbox update should be done.If the problem with this still continues, the gearbox may need to be revised.
08.05.2020 19:16 # 6
emreerdem78
Hello. I built the homeland peugeot in Ankara. Private service. They said it was original when putting on the piece, but we believe that the master said it because there is no subject we know.
I need to have a serious conversation with the service. Thanks for your comments.
08.05.2020 19:16 # 7
talip206
My teacher started knocking after the solenoid replacement, if it is necessary to change other places and do not expense, insist that he change the solenoid again. As a result, you have made 500 600 pounds of expenses for solenoid.
08.05.2020 19:16 # 8
emreerdem78
exactly, I gave 600 TL. He also said he had a guarantee. then I will get you done. I will ask for change. Thanks
08.05.2020 19:16 # 9
206cc57
Hello, are you still having problems, I am making a solenoid replacement plan.
08.05.2020 19:16 # 10
emreerdem78
Hello, the problem continues tomorrow, I will go to peugeota again, I met with the master, I will put the solenoids out of warranty and renew them.
It makes you feel more especially these days when the weather gets cooler, but it doesn't stay at the heat of the car.
08.05.2020 19:16 # 11
206cc57
I hope it will be easy to solve your problem in the easiest way, knock or automatic gear fault happens in the first 10 -15 minutes I drive the car until the engine gets hot. I will change the valves next week.
The knock when the gearbox is cold or the knock complaints / malfunctions that occur when the gearbox is hot are due to different reasons. I have been reading and following all internet reviews, including citroen, some users, after the overheating of the gearbox, some of them express their problems until the gearbox warms up, I hope everyone solves the solution in the most inexpensive and easy way.
08.05.2020 19:16 # 12
turgay307
Sister get well soon I suffered from solenoid malfunction. Thank goodness there is nothing left now, if they say they need to change another piece as their friends say, or if they will change, ask for solenoid money back.
08.05.2020 19:16 # 13
emreerdem78
it's really annoying. There was shout in the car when the first solenoid change, but the traction increased tremendously. My car has never accelerated so easily. But the next day the knock started in the morning and the shouting was already bothering me. Insha'Allah I will go to the service tomorrow morning. I also say that there is no logical vehicle in the market, I am renewed and let it be saved. For now, continue :)
08.05.2020 19:16 # 14
emreerdem78
I wonder where you had it built in Ankara, the solenoids
08.05.2020 19:16 # 15
emreerdem78
[QUOTE = turgay307] bro, I have suffered from the solenoid malfunction.
08.05.2020 19:16 # 16
turgay307
I had the aydoğan gearbox and it is a little expensive, but it does a guaranteed job. By the way, I have not met a very good master of gearbox. They connect the computer to the car, whatever they say. 8 solenoids had changed in my 2 months.
08.05.2020 19:16 # 17
emreerdem78
yes, i heard the sun rise. 8 pieces are already a good expense. Those in the market said that we would make the first solenoid change for 300 TL. I made 600 tlye in the country to be safe too :) now my thought is that when I go, do they say that other solenoid parts should change?
08.05.2020 19:16 # 18
turgay307
8 solenoids have changed but I only paid for the first solenoids, others are under warranty if you changed it in the country, go there if the vehicle gives automatic gear foult failure
08.05.2020 19:16 # 19
emreerdem78
Yes, the solenoid did not change, but now it gives the ramp error
08.05.2020 19:16 # 20
emreerdem78
I came to the homeland peugeot, when the morning was coming, he made another hit as the weather was cold, mubarek.
Page : / 2
