Knock under the car
08.05.2020 16:50 # 1
FeverDog
As the friends entered into a pit filled with water today, after stepping on the clutch, I could not forget the location of the brake and the downhill car accelerated into the pit. The inside of the water was pretty rough that it hit the gold violently. Then I continued on my way as if nothing had happened. Didn't really anything happen? Isn't it okay? :)
08.05.2020 16:50 # 2
ttaylanaa
Cartel pierceable plastic guards may break.
I hope nothing has happened.
08.05.2020 16:50 # 3
CEM1984
When it is removed when it goes to change the oil, look at the 206 cartel protection, rub it tight, if there is no going smoothly ...
08.05.2020 16:50 # 4
toga406
Since there is no warning light on the screen, "No Stopping, Stop, Go"
08.05.2020 16:50 # 5
ibrahim YILDIZAK
My car was destroyed by the ground, I had a crankcase cover to avoid such a problem, but since it was very close to the ground, I had to remove it when the casing did too much friction.
08.05.2020 16:50 # 6
erenoz
Did you joke when you said I forgot the brake?
08.05.2020 16:50 # 7
toga406
It's a joke in my mind
08.05.2020 16:50 # 8
oguzhan29
I hope there is a guard underneath the vehicle, or the cartel or something can be drilled, and the guard has preserved it if it's not too big anyway
08.05.2020 16:50 # 9
yigit4516
It shouldn't be hard to bend over and look under the car :)
08.05.2020 16:50 # 10
[QUOTE = yigit4516] It shouldn't be hard to bend and look under the vehicle:) [/ QUOTE]
Absolutely
08.05.2020 16:50 # 11
FeverDog
[QUOTE = erenöz] Did you joke when I forgot the location of the brake? peugeotturkey.com/smileys/smiley9.gif "border =" 0 "alt =" Embarrassed "title =" Embarrassed "/> & nbsp;
Thank you, your car I look at the bottom of the engine, but I do not understand even if the engine has started from there & nbsp; "Smile" & nbsp; Pretty low; If that guard will bring the car closer to the ground, it seems like the mountain slope never comes out. But he did not give a warning or something, he is arbitrary.
08.05.2020 16:50 # 12
atakanka
Well, lean over and check. If the steel cartel casing was not installed afterwards, the cartel casing, probably the original plastic, was torn or torn. because mine was like that. I had a patch on the oil change or something until I got iron but it was still not possible. I use it like that.
