KM Treatments ...
08.05.2020 15:42 # 1
• Oil filter with oil change. (5000/15000 KM)
• Air filter replacement. (5000 / 10000km)
• Fuel filter replacement. (10000 / 40000km)
• Pollen filter replacement. (5000 / 10000km)
• valve adjustment. (40000 / 50000km)
• Control or replacement of Firen pads (25000 / 50000km)
• Timing belt change. (30000 / 100000kmu)
• Fan belt control or replacement. (20000 / 50000km)
• Front layout control. (As for 20000km or sounds)
• Engine oil control (varies according to engine oil consumption)
• Transmission oil control (varies according to oil consumption)
• Defensive oil control. (Depends on oil consumption)
• Engine coolant control.
• Antifreeze freezing degree control.
• Wiper water control
• Tread depth control of tires
• Checking my ignition system.
• Steering system control
• Change if brake hydraulic oil check is old.
• A / C gas control
• Steering oil check, if necessary, change.
• Checking the tire pressures.
• AT gearbox oil check if necessary
• Electric system control (headlights signals heating etc.)
•Road test
• Battery check add battery water if necessary.
• Suspension control
• Headlight adjustment
• Rot balance
