KM time. Temperature Misfire Burning oil
08.05.2020 19:58 # 1
Psychotr21
Hi friends my car 2004 206 1.4 16v 90ps
Km sensor switched km does not show again what could be the problem?
Also, when traveling on the long road, there is no problem, water does not pass 85, but when I stop at that moment and stop the car immediately, the problem happens in degrees 110 when I start the contact within 1 minute.
And in every gear, it kicks in 2000 revolutions, shakes and shakes.
Sometimes it seems that at 3000 revs, the bottom gas cuts the swallow, becomes a little weak and walks again.
I use the BiraZ cycle, I do not shift gears before 2800, but at the most, I insert it into the cutter very occasionally.
The car decreases 800gr oil at 2000 2500km.
The power of the vehicle alone is very good at 160000.
Psychotr21 2016-09-18 12:20:11
08.05.2020 19:58 # 2
maestro
. maestro 2016-09-19 00:22:02
08.05.2020 19:58 # 3
maestro
. maestro 2016-09-19 00:21:46
08.05.2020 19:58 # 4
Psychotr21
No friends, more intelligent
08.05.2020 19:58 # 5
Psychotr21
08.05.2020 19:58 # 6
GokhaN
The km time is most likely due to the defect of the indicator time.
I have to look at the oil reduction engine from old gaskets or seals.
Shaking air flowmeter
it may be due to overheating.
First of all, it is necessary to check the robustness of indicator and bsi according to what you wrote.
