Km speed hand does not work (SOLVED)
08.05.2020 18:17 # 1
ROLAND
Hello friends, I have a 2001 model roland garros vehicle. There was no problem when I left the car in the evening, but I noticed that the km hand did not move in the morning.
Clap RESOLVED Clap
LOL friends I solved the problem with my own means I can help if there are those who have the same problem.
ROLAND 2014-03-03 11:11:27
08.05.2020 18:17 # 2
pusutr
Disconnect the battery terminal according to the rules, wait 2 minutes and then reconnect it. If it does not, there may be a speed sensor malfunction.
08.05.2020 18:17 # 3
furkanyakar
100 TL has fallen into it. Take it to a good electrician, he will remove the indicator and replace his engine. the lifetime of those engines is already 12-14 years already completed :) last year I had it too.
08.05.2020 18:17 # 4
pusutr
It had been the same for me. The pole got better after taking off the head.
08.05.2020 18:17 # 5
ROLAND
First let me try a battery. We did not go to the electrician. Thanks guys for your attention.
08.05.2020 18:17 # 6
furkanyakar
You're welcome :)
08.05.2020 18:17 # 7
ROLAND
I removed the battery head but it didn't notice anything, because the information screen does not work, we cannot enter the code of the tape. The tape does not work either.
08.05.2020 18:17 # 8
ekinoks44
I had my vehicle also the meter counter was not working, but it was automatic gearbox and there was a gear gear broken and it was about it. I worked hard until I solved the problem and even I used the vehicle for more than 1 year without running the meter. But I don't think your problem is so troublesome. Have the speed sensor checked, it might have been the first one. Again, there may be a problem with the gears on the display if you want to take a look at the panel.
