Km reset
08.05.2020 16:35 # 1
ozaannn
My dear friends, I will ask you something, I did the maintenance of the car, but the master who did not reset the mileage hour, I had seen it while resetting it, I did not do that, but I still know that there was a 20000 that I still couldn't have done it.
08.05.2020 16:35 # 2
fTh206
If you want to say that you are resetting the way you go when you say km reset, holding it for 10 seconds does not have any other way, so I reset it today!
08.05.2020 16:35 # 3
ozaannn
There is no mileage or bidet.
08.05.2020 16:35 # 4
This topic has been discussed many times in the forum. I called one of them in the link:
http://forum.peugeotturkey.com/forum_posts.asp?TID=17498&title=bakm-kilometresi-nasl-sfrlanr
08.05.2020 16:35 # 5
ocal24
When we get the fuel, press the km button that we reset while the ignition is off, at the same time, the ac flashes, then counts down for 10 seconds and the maintenance km is reset.
08.05.2020 16:35 # 6
gozem
[QUOTE = ocal24] hold the km button that we reset when the fuel is closed while the ignition is off, the ignition flashes at the same time, then counts down for 10 seconds and the maintenance km is reset
08.05.2020 16:35 # 7
Cmoss06
Turn off the ignition km reset button hold , turn on the ignition counts for 10 seconds and the service km duration is reset. "Smile"
08.05.2020 16:35 # 8
erkerd5429
[QUOTE = Cmoss06] Turn off ignition km reset button hold counts down for 10 seconds and service km time is reset. [/ QUOTE]
did this but it still hasn't been reset. & nbsp; I don't know how we can solve it?
08.05.2020 16:35 # 9
Cmoss06
When you press the button, there is a reset or change in km indicator. There may be a problem in your button.
08.05.2020 16:35 # 10
erkerd5429
[QUOTE = Cmoss06] When you press the button, there is a reset or change in km indicator. There may be a problem in your button. [/ QUOTE]
There is no change, I think it will be necessary to disassemble and look at the bottom of the button
& nbsp;
08.05.2020 16:35 # 11
Cmoss06
Either the pressed plastic & nbsp; end switch & nbsp; does not reach, or if the button switch is defective if it is charred, the button switch may have slipped in the coal under the tire.
