Km Key Sign
08.05.2020 21:06 # 1
peugeot55
What does it mean that the key symbol did not go out this morning on the km counter, my car peugeot 206 automatic gear 2001 model
08.05.2020 21:06 # 2
GokhaN
If the maintenance sign is not important, make your vehicle half contact, press and hold the keys on the instrument panel resets again 10 thousand km.
08.05.2020 21:06 # 3
peugeot55
Is there no harm if the brother has come care
08.05.2020 21:06 # 4
uzunca961
Maintenance time is either 10k km or 1 year normally.
You know the maintenance time better, whether I do it or not. It is of course beneficial for the vehicle to have vehicle maintenance on time
The decision here is yours
08.05.2020 21:06 # 5
GokhaN
[QUOTE = peugeot55] no harm if brother care has come
If it is time for maintenance, of course, the masters do not deal with resetting it when they do the maintenance, they leave it so I said so you can reset it
08.05.2020 21:06 # 6
ismailkaya
You can take a good look at your car's oil filters, spark plugs.
08.05.2020 21:06 # 7
peugeot55
Thank you brothers. I spoke to the master, oil change + 2filters, I am the foreigner of the subject, did it cost 200 TL?
08.05.2020 21:06 # 8
GokhaN
[QUOTE = peugeot55] Thank you bro! Thank you. I spoke to the master, oil change + 2filters, I am the foreigner of the subject, did it cost 200 TL?
oil filter, air filter, engine oil, you change the pollen and change the diesel filter if your car is diesel
08.05.2020 21:06 # 9
peugeot55
I have a vehicle with gasoline & LPG in-line system, it will be 4 months, oil change, air filter, oil filter change and antifreeze.
08.05.2020 21:06 # 10
GokhaN
[QUOTE = peugeot55] My vehicle has a gasoline & LPG in-line system, it will be 4 months, oil change, air filter, oil filter change and antifreeze, the total cost was 230.
Good luck, you will be comfortable in your mind after the maintenance.
08.05.2020 21:06 # 11
peugeot55
Amen brother, thank you all.
