km indicator malfunction
08.05.2020 20:25 # 1
ezio.auditore
Hello friends. I will ask for something, maybe if there is information about it, I will act accordingly.
now I bought the vehicle 7-8 months ago, my vehicle 206+ 2011 model vehicle had no problem until a while ago. some times — recently started doing often — the bar on the km hand stays at zero, it does not move, it shakes the car back and forth quite sensibly, sometimes it returns to normal and shows it if the bar speed escapes. After a while when it stays at zero, I throw it away after 5-10 minutes and the airbag warning light turns on. these three events occur depending on the km bar being constant. The driver shakes back and forth when the vehicle travels slowly, and stops when he accelerates. what is car breakdown
08.05.2020 20:25 # 2
talip206
Have your battery measured. Such deviations near the end of the battery can be observed.
08.05.2020 20:25 # 3
ezio.auditore
thank you
08.05.2020 20:25 # 4
razzmatazz
If the km sensor on the gearbox is broken, it will recover as soon as you replace it.
