Km hand problem on the go
12.06.2020 09:54 # 1
murataydin
Hello friends, there is a problem that often happens to me every day, while the vehicle is driving, the km speedometer goes to zero automatically after a few minutes, then it goes down again, what could be the problemhttps: //i.hizliresim.com/UYWAt5.jpgmurataydin2020-06 -12 09:55:42
12.06.2020 17:28 # 2
There is a km sensor, sir, it may be broken. Or the gears on the indicator motor may be stripping. need to disassemble and check.
14.06.2020 00:29 # 3
Brcbyrktr
A similar situation happened with mine. Interestingly, when the kilometer bar goes down to zero, the vehicle becomes monstrous, after a while it returns to its normal state when the bar is activated. As Sonerin said, the mileage sensor was out of order. Again, my brother Soner even helped.
16.06.2020 15:47 # 4
peugeotmagduru
hello, i have the same problem. The needle drops suddenly while driving. Then when I reduce the speed and press the clutch, the vehicle suddenly stops. No friends solving this situation. I poured a ton of money into the repairmen, but they still couldn't solve this problem.
05.07.2020 23:26 # 5
kaan206
The stepper motor is out of order.
04.09.2020 18:30 # 6
murataydin
I want to buy. Can you help me?
01.10.2020 14:55 # 7
mamuli
I had the same problem. I have the KM sensor and it was fixed when I changed the gearbox. However, do not install the supplier industry, because the gasket was bad, the transmission oil was missing when the vehicle was tilted to the right. I had to change with the original.
