kilometer wire has changed but still hand flickers
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Boxer
08.05.2020 16:54 # 1
kayx
In my car, I disassembled the clock to change the lamps of the mileage, I disassembled the mileage wire, I had to disassemble the mileage wire, then the needle began to vibrate, then they changed the mileage wire in the service again.
08.05.2020 16:54 # 2
AydinBeyol
Where did you press the grease? the needle & nbsp; itself may be damaged & nbsp; or the needle bearing & nbsp; may be defective.
08.05.2020 16:54 # 3
sahin-peugeot
Grease may have damaged
08.05.2020 16:54 # 4
kayx
[QUOTE = AydınBeyol] where did you press the grease? the needle itself may be damaged or the seat of the needle may be broken.
08.05.2020 16:54 # 5
kayx
[QUOTE = sahin-peugeot] Grease may have damaged [/ QUOTE] I don't think grease will harm, it was the same before applying grease.
08.05.2020 16:54 # 6
kayx
[QUOTE = AydınBeyol] where did you press the grease? the needle itself may be damaged or the needle bearing may be broken. [/ QUOTE] How much does it cost me or can I do?
08.05.2020 16:54 # 7
cgty86
The hands of the vehicles, which I know, have been reduced to km, vibrate and do whatever you do.
08.05.2020 16:54 # 8
kayx
[QUOTE = cgty86] I knew the lowered hour hand will vibrate and do whatever you do. It won't flicker.
