Keychain Problem, how do I solve it?
08.05.2020 14:01 # 1
Greetings;
The attached photo has the key to the 2003 206 X Line SW vehicle.
The part of the opening and closing buttons is broken as you can see as a result of the deformation. For now, I can reach the closing button with my finger, but the opening button starts to break in the button. .
The electronic parts of the switch work very well. What I need is only the safe.
I went to Trabzon / Bayram to solve the problem, they said we would change the key to 150 lira with the backup. but it makes you sick :)
How do you think I can handle this?
skes is 2009-02-14 00:20:08
08.05.2020 14:01 # 2
elenor
It will send an alarm to 50-60 for 150 safes.
08.05.2020 14:01 # 3
sinan-s
Unfortunately, the orj key system is coded and expensive
08.05.2020 14:01 # 4
OgUz
my friend brought this safe from abroad ... he was selling it for 50 liras ...
08.05.2020 14:01 # 5
[QUOTE = OgUz] my friend brought his case from abroad ... he was selling it for 50 liras ... if I could reach it and he stayed, I would write here ... [/ QUOTE]
Thanks to the friends who answered.
the alarm in the first answer seems more logical, if it is not resolved by the alarm, we can solve it with your friend, if it helps a little more in price :)
08.05.2020 14:01 # 6
OgUz
I http://www.sahibinden.com/peugeot_206_anahtar_kumanda_kutusu-01wqqaxqq12475791wqqpxqqdisplayite
here is the solution here is the discount: D welcome guys last two: D
oguz 2009-02-13 23:53:51
08.05.2020 14:01 # 7
If you can find the button of the ratio, find it and use it as you can comfortably use it as the old one after the band.
08.05.2020 14:01 # 8
sinan-s
If you can find [QUOTE = EmRaH] button down and find it with tape, you can easily use it as before :) No need to spend :) We have taped like the peugeots of our backbone .
I think it's a good method
08.05.2020 14:01 # 9
same in my bnm keyring. There is an electrical tape on it works smoothly
08.05.2020 14:01 # 10
tape panacea: D: D
08.05.2020 14:01 # 11
hasimayaz
Separate the cover from the electronic part. grease the whole case with grease oil .. then squeeze the silicone with a hot silicone gun to remove the silicone mold from the whole case. let it overflow slightly from the silicone holes. then immediately immerse it in cold water and remove the silicone that cools from it as a mold. Shave excess buttons with scalpel or cutter. Let the silicone stick you use be colored black.
hasimayaz 2009-02-14 20:52:32
08.05.2020 14:01 # 12
haruncoskun
[QUOTE = hasimayaz] Separate the cover from the electronic part. grease the whole case with grease oil .. then squeeze the silicone with a hot silicone gun to remove the silicone mold from the whole case. let it overflow slightly from the silicone holes. then immediately immerse it in cold water and remove the silicone that cools from it as a mold. Shave excess buttons with scalpel or cutter. Let the silicone stick you use be colored black.
Haşim brother, I love you, I admire your creative intelligence, walla, awesome thought =) ClapClapClapClap
08.05.2020 14:01 # 13
okan77
Kartal real praktiker at the entrance to the keymaker ... only the case is zero 40 TL. okan77 2009-02-14 21:15:48
08.05.2020 14:01 # 14
[QUOTE = haruncoskun] [QUOTE = hasimayaz] Separate the cover from the electronic part. grease the whole case with grease oil .. then squeeze the silicone with a hot silicone gun to remove the silicone mold from the whole case. let it overflow slightly from the silicone holes. then immediately immerse it in cold water and remove the silicone that cools from it as a mold. Shave excess buttons with scalpel or cutter. Let the silicone stick you use be colored black.
hazim ayaz = technical responsible
fulfilled its responsibility Smile
08.05.2020 14:01 # 15
EMRE
congratulations on super idea, hasim brother Clap
08.05.2020 14:01 # 16
In one word Clap
Congratulations, teacher.
It is a method that can be done by removing a little bit of workmanship. It can also be applied in many different places (in many places where there is a lack of buttons :))
Thanks also to the friends who helped with the box.
I conclude as soon as possible and write here.
08.05.2020 14:01 # 17
http://www.dealextreme.com/details.dx/sku.16655
08.05.2020 14:01 # 18
H-a-d-i
I read this topic last week. and while I was walking around the bazaar I saw the case of the Peugeot ignition key in the key. I asked the price.
only plastic case, there are two types as 30 TL and 50 TL. I'm in Istanbul and I can help if you want.
If you consider turning your key to a switchblade, you need to give 100-120 TL in the Istanbul market.
08.05.2020 14:01 # 19
ErkanKurnaz
e-bay also had a snap model for 206 I liked it very much
Besides, Haşim, you are in love every day :))
08.05.2020 14:01 # 20
ukubilay
My friend, I have the same trouble, I asked him, I went, I bought it for 30 lira, I just changed the case, the problem was fixed. If you want, I will give you the address and the wire.
Page : / 2
