Key symbol in the indicator of 306
08.05.2020 16:49 # 1
aykut06
first of all thank you for the management of this site and the comments made by friends on this site, i believe it is very useful thank you for your interest. & nbsp; I bought the model model pejo 306 xr 2 months ago, when I bought it, I had trouble with the clutch and the fit, and there was a little bit of noise when I pressed the depression. As soon as I pressed the clutch pedal of the vehicle, the pedal was stuck and the little noise that came out of the vehicle came out and the fits did not pass. It probably feels like ate the clutch lining.I also wonder that this is the key symbol that burns along with the km when it is turned on. I am a new and inexperienced car care provider, what would you recommend?
Thanks for your interest in advance ...
08.05.2020 16:49 # 2
aykut06
also on the license of this tool & nbsp; It says 306 1.6, but the cylinder cross 1761 & nbsp; This vehicle shows 1600 enginem 1800 enginem ..pejo 1999 xr model gasoline ...
08.05.2020 16:49 # 3
muho
Yes, the key symbol remains on because the connection to this engine shows that there is a problem with the fault light and possibly the clutch wire may have broken the same thing happened to me. When the problem is resolved, the illumination light that goes on will go out.
08.05.2020 16:49 # 4
aykut06
yeah right now, if one of the service is going to go from where I go, the vehicle will not cost much, thank you .. thanks
08.05.2020 16:49 # 5
muho
If I remember correctly, I bought the wire for 35-40 liras, and I changed it for 20 liras. but not service, I had a master in the industry, if it is in service it will be higher price.
08.05.2020 16:49 # 6
aykut06
şal telidiridiridiridir tel tel tel tel tel ama ama ama but can it be in the clutch lining? If it happens, it sounds like 500 places from the head.
08.05.2020 16:49 # 7
aykut06
Did your car show the indicator key sign without this incident
is stuck in my room head, they call tyag but it was burned 3 days before this incident, the oil condition is not good lacking and pollution, is it due to clutch failure this key symbol
& nbsp; < / DIV>
08.05.2020 16:49 # 8
[QUOTE = aykut06] is the string, but it may be on the clutch lining? If it happens, it sounds like 500 places from the head, it sounds very exaggerated because when you press the depression ..
Hello,
We would like to get to know our new members closer. In this context, I would appreciate if you can reach the link below.
http://forum.peugeotturkey.com/forum_topics.asp?FID=22&title=yeler%DDm%DDz%DD-taniyalim
What is the maintenance of your key symbol vehicle shows that it is up. It starts to flash and even beep for a certain kilometer. I don't think he has anything to do with clutch or gear from afar.
08.05.2020 16:49 # 9
toga406
the engine volume may have been processed incorrectly. when selling, I think the problem may be correct, I think it is the negligence of the officer
