Key sign next to km
08.05.2020 20:46 # 1
Gokceli
Selam aleyküm friends I have a peugout 206 sw vehicle when working in the place where 2004 model km is working, there is a key sign right now it says 7300 it decreases as we use it.
08.05.2020 20:46 # 2
pusutr
filter and oil changes are required.
08.05.2020 20:46 # 3
maximusti
the maintenance sign starts to give the warning every 12 months or every 10000 km.
08.05.2020 20:46 # 4
talip206
Shows the remaining maintenance time. To reset after oil change, press the km reset button while the ignition is off. The contact opens without taking your hand. It starts counting down from 10 on the screen. When it is zero, the hand is drawn. Thus, it is reset.
08.05.2020 20:46 # 5
Gokceli
Thank you friends
08.05.2020 20:46 # 6
yigit_dark
If you want to get on top of it, you can take care of it.
The ignition is off. Press and hold the km reset button. Turn on the ignition without releasing the button. When you wait 10 seconds, the countdown will count down on the screen and the maintenance km will be renewed. The key will disappear in the sign.
20.02.2023 16:51 # 7
Seyyit han kul
Adamsin solved, for the first time I found the solution of something in forms
