Key sign in 106
08.05.2020 15:45 # 1
darknes0808
It has been 1 month fln since the vehicle has been cared for. The maintenance is over 2,000 km but when I turn on the ignition, the flashing key sign comes on and after a few seconds the km counter comes and I start the car. Why does this key sign come?
I Hizliupload.co
I Hizliupload.co
08.05.2020 15:45 # 2
berk2309
If they did not reset the maintenance counter after the care, you have to light up the brain and show that the care is coming.
08.05.2020 15:45 # 3
While holding down the button on the left side of the display screen, you turn the contact. Then you will see that the indicator will start counting down from 10. Then turn off the ignition (you are still holding down). Then the process is ok.
08.05.2020 15:45 # 4
darknes0808
[QUOTE = koliva] While holding down the button on the left side of the display screen, you turn the contact. Then you will see that the indicator will start counting down from 10. Then turn off the ignition (you are still holding down). Then the process is ok. [/ QUOTE]
eyw bro I had to put it on this topic. It started counting back from 20,000 :)
08.05.2020 15:45 # 5
[QUOTE = darknes0808] [QUOTE = koliva] You press the button on the left side of the display screen while pressing the button. Then you will see that the indicator will start counting down from 10. Then turn off the ignition (you are still holding down). Then the process is ok. [/ QUOTE]
You're welcome.
