Key renewal
08.05.2020 20:43 # 1
necmettinn
I replaced the outer cover I brought with Aliexpres from the old one ... The total cost is 6.50 TL. There are visuals in the place I mentioned about the change, you put the inner circuit directly in the new one. When you keep the switch part half open, there is a small pin and you can change it after removing it. If you want, you can copy the incoming key at the unlocking key, but if your key is intact, I think it is not necessary.
Announced to those in need ...
Good evening....
08.05.2020 20:43 # 2
x571
Can you send a link
08.05.2020 20:43 # 3
necmettinn
https://tr.aliexpress.com/item/for-peugeot-307-107-207-407-408-car-remote-flip-car-key-cover-shell-case-3/32819090940.html?spm= a2g0s.9042311.0.0.nefmmp
The key part about the change of the key part I mentioned is not in this product, but this is the product I bought ... it came to an estimated 25 days, but the product sold here for 25 TL came to 6.50TL ....
If you want to change the key part, I can take a photo and then throw it ...
08.05.2020 20:43 # 4
Furkan979
Good luck bye
08.05.2020 20:43 # 5
Ufuk_64
Thanks to your health, I opened my key and saw what you have inside. My switchblade does not close, I always showed it to the open service. He said something like 500 TL.
08.05.2020 20:43 # 6
necmettinn
Thank you...
If you look at the site I mentioned, you will most likely find it because there are so many kinds ...
The ones with three keys do not exist in the ones with battery slots. Mine is without batteries, for example.
If you want, send a photo of it and I'll look and send you a link here ... If you say the same , you will order ...
NECMETT Tallinn 2018-01-07 22:43:24
08.05.2020 20:43 # 7
[QUOTE = Ufuk_64] Thanks to your hand, I opened my key and saw what's inside. My switchblade does not close, I always showed it to the open service. He said something like 500 TL. [/ QUOTE]
teacher, I use three keys of this. binary will be enough for you. it is more aesthetic because it is original two-button Smile
https://tr.aliexpress.com/item/keyyou-2-buttons-modified-filp-folding-remote-car-key-shell-case-for-peugeot-307-408-308/32831299508.html?spm= I & ws_ab_test a2g10.search0104.3.51.ivew = searchweb0_0, searchweb201602_1_10152_10151_10065_10344_10068_10342_10343_10059_10340_10314_10341_10534_100031_10084_10604_10083_10103_10307_10615_10142, searchweb201603_25, ppcswitch_5 & algo_expid = f54b5ba6-3ca4-4343-b30-b30 of a-5db08a3ab734-7 & algo_pvid = f54b5ba6-3ca4-4343-5db08a3ab734 & pricebeautifyab = 0
08.05.2020 20:43 # 8
Ufuk_64
Thank you guys for your ideas. It seems to me that I will not be able to do it because I have never done shopping like that. But at least thanks to our friend, I learned that I will change the container when I find the container, the battery was dead, it was not charging, let me go and look at the battery soon.
08.05.2020 20:43 # 9
x571
[QUOTE = necmettinn] https://tr.aliexpress.com/item/For-PEUGEOT-307-107-207-407-408-Car-Remote-Flip-Car-Key-Cover-Shell-Case-3/32819090940 .html? sPM = a2g0s.9042311.0.0.nefmmp
I like it. Even if there is a video, it would be better. I would like to buy it and change it.
08.05.2020 20:43 # 10
husem
I want to ask something else. I had a second switch from the keymaker. Can I sell my car and recode it for my new car? Would it be with pp2000?
08.05.2020 20:43 # 11
Barbarosa
I don't have a trunk key in my key. How do I do it?
08.05.2020 20:43 # 12
[QUOTE = Barbarosa] I don't have a trunk key in my key. How do I do it?
unfortunately hb does not happen on vehicles bro. my trunk open button is introduced with the headlight on / off feature activated or you cannot open the trunk
08.05.2020 20:43 # 13
necmettinn
I know that once the key is encoded, the key cannot be re-encoded.
08.05.2020 20:43 # 14
necmettinn
There is a fine notch at the bottom of our key. From there it will open when you press the screwdriver and lift the top cover a little.
Mechanism that keeps our round place switch with two notches under the top cover closed when we close it. The key does not remain in the closed position if the recesses here are deformed. So he can not do susta.
Be careful when removing the pin on the key part ... Don't hit your original key too hard ... If you want to change this part, you can copy the original on a newly arrived flat key in a keymaker. I removed this pin and put my old key on the new case.
I tried to explain by writing on the pictures ... I hope it works for you ... Good evening ...
NECMETT Tallinn 2018-01-08 22:19:30
08.05.2020 20:43 # 15
necmettinn
Don't look at my two pictures reversed flaw Tongue
08.05.2020 20:43 # 16
Ufuk_64
Let me write a footnote. Today, I replaced it with the complete key, so a new key was drawn to the key that came on it. The unlocking friend explained why it broke, the reason is that we press the button when opening the key, but the nails wear out because we do not press it when closing it. So, when closing, we have to press the button and turn it off.
08.05.2020 20:43 # 17
necmettinn
[QUOTE = Ufuk_64] Let me write a footnote. Today, I replaced it with the complete key, so a new key was drawn to the key that came on it. The unlocking friend explained why it broke, the reason is that we press the button when opening the key, but the nails wear out because we do not press it when closing it. In other words, we need to press and close the button while closing. [/ QUOTE]
I agree exactly ... Even if we can, we press the button until it closes completely, it will have a longer life ... LOLLOLLOL
08.05.2020 20:43 # 18
Barbarosa
My key is my 2-key teacher. How can I adapt this shuffle?
08.05.2020 20:43 # 19
[QUOTE = Barbarosa] My key is my 2-key teacher. How can I adapt this shuffle? [/ QUOTE]
type 1
https://tr.aliexpress.com/item/jingyuqin-modified-flip-folding-remote-key-shell-fit-for-peugeot-307-607-207-for-citroen-c2/32825955244.html?spm= a2g10.search0104.3.45.6153f of & ws_ab_test = searchweb0_0, searchweb201602_1_10152_10065_10151_10344_10068_10342_10343_10059_10340_10314_10341_10534_100031_10084_10604_10083_10103_10613_10307_10615_10614_10142, searchweb201603_1, ppcswitch_5 & algo_expid = a3310a99-d8cc-4e8b-8e42-b2841e0217f2-6 & algo_pvid = a3310a99-d8cc-4e8b-8e42-b2841e0217f2 & pricebeautifyab = 0
Type-2
https://tr.aliexpress.com/item/2-buttons-remote-car-key-cover-for-peugeot-307-2-buttons-modified-flip-remote-key-shell/32819074805.html?spm= a2g10.search0104.3.52.6153f of & ws_ab_test = searchweb0_0, searchweb201602_1_10152_10065_10151_10344_10068_10342_10343_10059_10340_10314_10341_10534_100031_10084_10604_10083_10103_10613_10307_10615_10614_10142, searchweb201603_1, ppcswitch_5 & algo_expid = a3310a99-d8cc-4e8b-8e42-b2841e0217f2-7 & algo_pvid = a3310a99-d8cc-4e8b-8e42-b2841e0217f2 & pricebeautifyab = 0
My teacher, the interior of your key is different as in the picture
If you want your key snap, you can get this type of snap key container. I bought 206 vehicles, I did it. all you have to do is insert the inside electronic card and open the key tip.
sonerkyl 2018-01-09 10:46:43
08.05.2020 20:43 # 20
necmettinn
As my sonerkyl said, the electronic circuit is different between two keys and three keys. I think it would be more convenient to take the appropriate cover and mount it instead of adapting it to the case ...
Page : / 2
