key problem |
| 08.05.2020 17:53 | # 1 |
I replaced the container of the Peugeut 307 remote key. I can open the doors with a key. I turn the ignition to start it does not work. I use it with a backup key. what can I do? |
| 08.05.2020 17:53 | # 2 |
Hodja, there will be a small chip in the key case that you replaced. |
| 08.05.2020 17:53 | # 3 |
I did not insert anything other than a battery installed circuit.
| 08.05.2020 17:53 | # 4 |
teacher, look at the container you have changed, it will be a small chip without it, the vehicle will not work, if you did not throw the old container, look at it :)
| 08.05.2020 17:53 | # 5 |
Thank you teacher. Hopefully it has not been thrown.
| 08.05.2020 17:53 | # 6 |
you are welcome, i hope it is not discarded, if they did, you can also insert it from the same chip inside the spare key, you can insert it into your new key case :)
| 08.05.2020 17:53 | # 7 |
outlaw |
IMMOBILIZER BUT BE CAREFUL ...
