|   | Key issue |
| 08.05.2020 21:07 | # 1 |
| 08.05.2020 21:07 | # 2 |
|  sonerkyl | |
My teacher can not open the door locks with the key for a long time, such problems can occur. I was able to open it in my old focus tool. the other possibility is that the key may have changed. It is a more common situation that I wrote first.
| 08.05.2020 21:07 | # 3 |
[QUOTE = sonerkyl] My teacher cannot open the door locks with the key for a long time, such problems can occur. I was able to open it in my old focus tool. the other possibility is that the key may have changed. It is a more common situation that I wrote first. [/ QUOTE]   My teacher has the original key, he said that I will send the person I bought in the vehicle. It's not the original I use now.  | |
| 08.05.2020 21:07 | # 4 |
|  27BEN80 | |
the key is the same, even if it's not the original, you probably try the vd 40 la
| 08.05.2020 21:07 | # 5 |
[QUOTE = 27BEN80] is the same even if it is not the original key you probably try with vd 40 la i think [/ QUOTE]   I'll write the results I will try tomorrow here  | |
| 08.05.2020 21:07 | # 6 |
|  27BEN80 | |
watch out for breaking the key    | |
| 08.05.2020 21:07 | # 7 |
|  OguzhanKucuk61 | |
In addition to these,   I had to make a spanner key and reopen it. The newly opened tip went into the door lock but could not turn. I took him to the keymaker, he raspled his left and right, opening and closing. It may also be due to this. Get well soon.  | |
| 08.05.2020 21:07 | # 8 |
friends and I was afraid. We went to the guesthouse after five hours, when we came back to the car to return home, the doors do not open. The controller does not operate. As I said before, the doors do not lock out of the existing key key hole. There is only contact and control function. When buying the vehicle, the seller had robbed the door, it was not original that the door was not urgent. We are in the middle. I came to my house by taxi. The vehicle is already a single door. There is only one key place. What am I going to do now? How do we open these doors? Help please :(((
| 08.05.2020 21:07 | # 9 |
|  recepagdas | |
My teacher, I can not open the doors from the control, I have been studying for about half an hour. Get well soon. I can also open the door handle. My key is not the original, but the watermelon like you. But interestingly, I can't open the doors remotely as if the battery of the controller is exhausted. No reaction. But everything is normal by twisting the arm. It has a spare key, old. It doesn't hurt either. Sometimes when the car starts to run on its head, I try the spare switch and it works. So I have it in my car, but I don't know who will help us.   I think your problem may be from the battery this time. Because you were using it normally until this time? Ok the key is not original, but if that contact opens once, it will always open. Maybe your contact has also changed, so the owner of the door has not changed the lock before. But you could open and close the doors remotely, I think you may have run out of batteries by this time? Though mine responded as if the battery was exhausted but the battery did not come out. Maybe you are having the same problem with me right now, but it is worth trying. it uses 2 of my sustali cr2016 battery.  | |
| 08.05.2020 21:07 | # 10 |
I don't know how it will be. I left the car and came there by taxi. Remote does not work. The key does not freeze at the hole. I think the contact has changed before. They introduced the remote to the car. There are no keys opening the doors. Of off
| 08.05.2020 21:07 | # 11 |
What should I do now? How can I open the door with the key I have? Can I follow the lock that is compatible with the key in my hand?
| 08.05.2020 21:07 | # 12 |
|  recepagdas | |
If you find an electronics store that sells such batteries, both look at the voltage of the battery that comes out and replace the batteries. Try it. You can share the result here again.
| 08.05.2020 21:07 | # 13 |
[QUOTE = recepagdas] If you find a place that sells batteries like an electronics store, you can both look at the voltage of the battery and change the batteries. Try it. You can share the result here again. [/ QUOTE]   Sir, this is not really a permanent solution. In the future, if there is a bidet, water will run or something will be the same. I want to lock in the door with my key now. What should I do for this? Do you need to change the door lock according to the existing key or set it according to this key?  | |
| 08.05.2020 21:07 | # 14 |
|  recepagdas | |
If you can open the door, of course you can do it, hodja. But it seems like it is difficult from outside. Worst of all, you will find a set with the same key in which the mechanism in the contact and door handle is the set. Maybe it sells extractors, perhaps even in pieces without immobilizer. You can not change the key, you just change the tip, the pin comes out and it can change. Of course these are the last care.
| 08.05.2020 21:07 | # 15 |
friends have changed the battery but it still doesn't hurt. How will we open this door?
