key does not turn
08.05.2020 18:32 # 1
adali
my vehicle 2003 307 1,4xr hdi. we went somewhere today. We stopped. When I go back to the car and try to start the car, the key is to turn in the ignition. the key does not move even when the steering is locked left and right. I wonder why. This would have occasionally been small. the steering wheel would be straightened a little, but this time the key never turns. We called the auto electrician. He said that the contact would be removed and corrected in the unlocking device and replaced back. I would appreciate if you help.
08.05.2020 18:32 # 2
alikrcoglu
man, under normal circumstances, when the steering wheel moves slightly, the steering wheel is locked and the key needs to be turned on.
08.05.2020 18:32 # 3
adali
do you have the same problem?
08.05.2020 18:32 # 4
alikrcoglu
No, I have a starter problem in my car. When I turn the key, there is a single thump sound, the car is clogged and not working.
08.05.2020 18:32 # 5
adali
the electrical problem of these pejos is too much now i am bored
08.05.2020 18:32 # 6
alikrcoglu
may be brothers, electrical problems, my first vehicle is my pejo ... starter dynamo coal and a part of the engine oil petrol filter changed, I charged the battery in the evening, came to the vizier bridge from the evening, parked the car, went to the hospital, did not work, of course, went up the hill, gave a different money to the master, the problem could not be resolved anyway. I'm about Smile No one can reply to the topic I opened in the forum, I think the only problem in the world
08.05.2020 18:32 # 7
enes_468
If the problem is in the contact, pull the engine oil dipstick, drop a few drops in the key and turn the contact back, when this lubrication is done 3-5 times, the contact hub will be lubricated and the installed contacts will be able to open and close easily.
08.05.2020 18:32 # 8
adali
wd40 squeezed but 2 plugs did not work
08.05.2020 18:32 # 9
enes_468
According to what he said he was doing at that time, he had been dying before, and the last incident was deceased and the groove in him died. It means that the contact hub will change.
08.05.2020 18:32 # 10
adali
I hope we get away without anything too costly.
08.05.2020 18:32 # 11
oguzhan29
We had a professional key in our car. He said if there was contact kit or something, but I forgot
08.05.2020 18:32 # 12
akantek
Well, brother, I took it to the keymaker because he knows the same thing happened to me, but the cucumber broke the key inside the contact. then we removed the contact.
The new kit 450 only said 250 TL if you want a contact. but if you just changed the contact, I would have to use different keys to the doors and contacts.
Thanks to a friend of mine, I got the r9 contact and adapted the password in mine, the electrician also changed the sockets.
