key does not fit in contact (fixed)
08.05.2020 15:54 # 1
deamod
Selamun aleykum guys
Today, I disassembled the steering wheel, I played the fln with the indicators, changed the lights that were broken, etc. etc at this time, my little cousin was next to me. I held the battery, I removed the battery, and I saw the key, so when I forget the key, the sound of the vibrant sound is heard, but the key does not fit properly. How can I handle it?
deamod 2011-07-30 21:19:12
08.05.2020 15:54 # 2
peugeotefe
Passwords in your vehicle's contact may be scattered.
08.05.2020 15:54 # 3
deamod
So what should I do? Can I handle it myself or is it necessary?
08.05.2020 15:54 # 4
Maybe it is necessary to change if zeroes are distributed. a little bit crippled
08.05.2020 15:54 # 5
deamod
How do I know if the passwords are distributed?
And if it is not distributed, it may cause another?
08.05.2020 15:54 # 6
peugeotefe
If the password is scattered, the contact will not be seated. If there is a locker nearby, you will call and disassemble the contact. If it can save your contact, you will get a new contact. peugeotef to 2011-07-29 12:38:51
08.05.2020 15:54 # 7
deamod
You call the keymaker?
08.05.2020 15:54 # 8
deamod
Locksmith?
08.05.2020 15:54 # 9
deamod
Please help
08.05.2020 15:54 # 10
metin
yes they call the lockers, unlocking, go to the nearest industry you will find open the steering wheel cover and remove the ignition. If it does, you will get a new contact.
08.05.2020 15:54 # 11
deamod
Now I can't go to the industry because it doesn't enter the key, I'm in Bursa and I don't know who I need to go here. Bid, I don't even know how to go where the industry is.
08.05.2020 15:54 # 12
It doesn't necessarily have to be an autolocker to remove it. You will find a key-locker between the neighborhood. You will remove the contact. With a contact in one hand and a contact key in the other, you will take the path of your industry. If it is not repaired, you will have to replace the entire lock set, which is quite burdensome. Because I have one key; I open the door, the trunk and the ignition. You probably are too. When you change the ignition, you will need to change them.
08.05.2020 15:54 # 13
deamod
[QUOTE = Menderes] It doesn't necessarily have to be an autolocker for removal. You will find a key-locker between the neighborhood. You will remove the contact. With a contact in one hand and a contact key in the other, you will take the path of your industry. If it is not repaired, you will have to replace the entire lock set, which is quite burdensome. Because I have one key; I open the door, the trunk and the ignition. You probably are too. When you change the ignition, you will need to change them too. [/ QUOTE]
Just like that, according to the key in my hand, they can't do this job, so if I get a new contact, they can't adapt to the key in my hand.
I can not disassemble this contact by myself. I have to find my keymaker?
08.05.2020 15:54 # 14
iibrahimm
The master has a small key in the back of the courthouse in Bursa and I could not find the single address tel no.
08.05.2020 15:54 # 15
deamod
Can I put the contact in one press?
08.05.2020 15:54 # 16
iibrahimm
master, I also have a little problem with the contact, because I did not look at how to disassemble it because I somehow disassemble it, I try to repair it myself, I am all afraid of it, but I am afraid of myself.
08.05.2020 15:54 # 17
deamod
Wala in my mind, if I put that pass, I would try to fix it, the indicator was defective already.
08.05.2020 15:54 # 18
iibrahimm
I am very sorry but there is a saying that it is ready for the moment. Wall I tried hard, turned back to the waist, left the terminal, came home again, and worked again in the same way for 30 minutes.
I removed the imoblizer, I did not remove the electric part, but I could not remove the password part, there is a pin in sight that it is holding, but I could not remove it dw 40 to wash it thoroughly, then I kept the air now a little better but still hangs a bit
Do you think the key itself may have been worn?
08.05.2020 15:54 # 19
mehmet1965
I had the same problem, and I was able to collect back as I had, thanks to my hand skill, but I had to decrease one of the things that had been deformed too much, but if you have a hand skill, you can do it. If you say I will take time, I will do it for your help 05065828199
08.05.2020 15:54 # 20
deamod
I will do it :) I have a talent for the first time. I will insert a key for the first time.
Page : / 2
