Key Container Replacement.
08.05.2020 20:27 # 1
Peugeot35
The key switch I ordered from CHINA came with the key, the key alignment of the key is the same as the original key without the key inside the card, can I transfer these containers to each other? If it is not possible, I will never open the box of the newcomer. Smile If there is a buyer, he can see the good.
Both case empty box + silicone case
Peugeot35 2017-07-12 13:43:16
08.05.2020 20:27 # 2
Oktkor
I think your key from china is more accurate than your key :) Your key is incorrect than the original. They officially scrolled. You already stepped on the edge of that circle, I think it seems to be stretched in.
I don't understand the other problem, open it, look at both of them. It is unreasonable to say anything without seeing.
08.05.2020 20:27 # 3
KILIC
how much do you say to the silicone case :)
08.05.2020 20:27 # 4
Peugeot35
[QUOTE = SWORD] how much do you say to the silicone case:) [/ QUOTE]
I want a 40 TL for the two.
08.05.2020 20:27 # 5
Peugeot35
It is for sale.
(two 40 TL will be delivered to the desired cargo on the same day. cargo must pay against.)
Peugeot35 2017-07-15 02:21:38
08.05.2020 20:27 # 6
Peugeot35
[QUOTE = Oktkor] I think your key from china is more accurate than your key :) Your key is wrong from the original. They officially scrolled. You already stepped on the edge of that circle, I think it seems to be stretched in.
I don't understand the other problem, open it, look at both of them. It is unreasonable to say anything without seeing. [/ QUOTE]
I think I got it wrong :) because the button is almost right below the pressing area, there is absolutely no scroll. With this card, I can turn the card inside the remote control into a different original triangle key.
unfortunately this did not adapt to the switchblade.
08.05.2020 20:27 # 7
Oktkor
How is your new purchase, sir?
08.05.2020 20:27 # 8
Peugeot35
[QUOTE = Oktkor] How about the new one, hojam? [/ QUOTE]
it's the same
This should be the snow in the box that is suitable.
08.05.2020 20:27 # 9
ggitaristt
As far as I understand, your original key is not switchblade. They put on a container that turns the normal flat key into a switchblade. You have to find the same ..
08.05.2020 20:27 # 10
Peugeot35
[QUOTE = ggitaristt] As far as I understand, your original key is not switchblade. They put on a container that turns the normal flat key into a switchblade. You have to find the same ..
If I am not wrong, the peugeot 307 does not have a switch with a switch, because all of the keys I bought are used in cars like hawk-born letterpress.
the original key is triangular in shape, one of which is controlled and the other is ex-factory. Correct it if I'm wrong. Most of them are in peugeot users, even those who are the first owners of the pug.
08.05.2020 20:27 # 11
Exactly, I bought it for the 206 car from the product in the link.
08.05.2020 20:27 # 12
Peugeot35
[QUOTE = sonerkyl] exactly, my teacher, I bought it for the 206 tool, I use it without any problem.
soner teacher is this shell compatible with the card in my shell? nice to let me order.
08.05.2020 20:27 # 13
[QUOTE = Peugeot35] [QUOTE = sonerkyl] exactly, I use it for my 206 vehicle from the product in the link.
I use the compatible teacher, your card and mine will not be the same problem. But be careful, how is your tip or your inner type?
08.05.2020 20:27 # 14
Peugeot35
[QUOTE = sonerkyl] [QUOTE = Peugeot35] [QUOTE = sonerkyl] exactly, I used it for my 206 car from the link in the link, I use it without any problem.
the tip is straight?
08.05.2020 20:27 # 15
Peugeot35
[QUOTE = Peugeot35] [QUOTE = sonerkyl] [QUOTE = Peugeot35] [QUOTE = sonerkyl] exactly, I bought it from the product in the link for my 206 vehicles, without any trouble.
I gave up the switchblade, I took the original key from the key and assembled the card so I will use the chip alone.
08.05.2020 20:27 # 16
ggitaristt
@ Peugeot35 The pejoes after 2005 are original switchgears. You're right .. Your friend had a 2003 307 xt premium wasn't so shy ..
08.05.2020 20:27 # 17
mustafa46
sonerkyl bro you threw the link to sleep
08.05.2020 20:27 # 18
Suitable link for 307s
08.05.2020 20:27 # 19
Peugeot35
As you can see in the pictures, I put the jeep's jeep in the box with Japanese.
I called the keymen and they wanted 100 TL for the broken jeep. Switchback pattern has already been disorganized garbage dump, apparently, it was costly to replace the switchgear.
Well known, I went to the keymaker I went to, the original keyed key case + jeep + opening of the key tip, all of them agreed with 100 TL, I think I was on my lucky day today.
NEW ORIGINAL KEY
NOTE: If I hadn't got this spare key that was told to me alone, the cost would be 4 times + if someone who didn't know it would be connected to the car, the central lock would be deactivated.
08.05.2020 20:27 # 20
I have made a spare key for my teacher to get past, I was introduced with the peugeot planet program, because the securty codu of the vehicle is 35 TL.
Page : / 2
