key coding
08.05.2020 15:04 # 1
%106
I can't start my car with my backup key
what should I do?
Would it be enough to have coding
where and how can i deposit
08.05.2020 15:04 # 2
GokhaN
you can get the most solid in the service.
08.05.2020 15:04 # 3
dinoco
[QUOTE = GökhaN] you get the most robust service in the service, the cost of dealing in vain is around 110-140 TL [/ QUOTE]
if this is the service price, you should have it done in the service.
locksmiths
08.05.2020 15:04 # 4
[QUOTE = 106%] I can't start my car with my backup key
what should I do?
1. Turn the ignition to the ON position using the vehicle's first key. Previously from the vehicle starting position. The doors will be closed in this case.
2. Press and hold the locking button on the switch for 10 seconds, then release it. Make sure that the battery in the key is intact and charged.
3. Take the key from the contact and wait 10 seconds. Then press and hold the lock button on the key you will re-code for 10 seconds.
4. Check that it is coded correctly. It doesn't really matter, but when doing this, get out of the car and insert the key you code into the lock on the door. In this way, check if the vehicle is properly locked. Then remove it and try it remotely.
Koliva 2011-01-30 14:56:35
08.05.2020 15:04 # 5
I understood and answered how the remote control was coded. I think I misunderstood Gülme
08.05.2020 15:04 # 6
GokhaN
[QUOTE = dinoco] [QUOTE = GökhaN] you get the most robust in the service. The cost of dealing with unlocking is around 110-140 TL.
locksmiths
As far as I know in the 206 and 106, the duty of the spare keys is not just the remote control feature to open the doors and start the vehicle. I bought the price for 206 2 months ago was 130 rubles. The price I get is Peugeot Aç - İstanbul Üsküdar
08.05.2020 15:04 # 7
dinoco
[QUOTE = GökhaN] [QUOTE = dinoco] [QUOTE = GökhaN] you get the most robust in the service.
locksmiths
yes I got it wrong too sorry
08.05.2020 15:04 # 8
hanniball35
Is immobilizer key coding done with peugeot planet program?
08.05.2020 15:04 # 9
ibrahim YILDIZAK
Go to any peugeot service doesn't need to be an authorized service. They coded your key as a single key from bsi. They encode both keys and they handle something by hand. not in the 150s
08.05.2020 15:04 # 10
hanniball35
Friends, I bought a lexia & planet pp2000 adapter from abroad. I have two keys belonging to my vehicle, but one does not work. I ask someone for help.
08.05.2020 15:04 # 11
[QUOTE = hanniball35] Friends I bought lexia & planet pp2000 adapter from abroad.I have two keys belonging to my vehicle, but one does not work. I do not know how it is being done.
When you enter PP2000, you will see an option under the BSI menu called key coding. I haven't done it until now, but PP2000 will help you enough already. If you have never used PP2000 so far, I recommend you pay attention while walking around. If you want to tamper with it, keep in mind what you are doing and write it down, or write it down so that you can return later.
08.05.2020 15:04 # 12
hanniball35
I found the coding place in pp2000 but he asked me for a code from the technical service.
08.05.2020 15:04 # 13
[QUOTE = hanniball35] I found the coding location in pp2000 but he asked me for a code from the technical service or whatever he says what code is the service will give me that code [/ QUOTE]
4 digit transponder code o. You know the tape code or something.
08.05.2020 15:04 # 14
kktcumit
I recently took the 307 min key disappeared to the service with the tractor
they made the key for 220 euro. there was a euro campaign I paid 440 TL
08.05.2020 15:04 # 15
hanniball35
So, the 4-digit code is not valid in pp2000.
08.05.2020 15:04 # 16
[QUOTE = hanniball35] so my 4-digit code is not valid in pp2000 teacher.
I didn't quite understand the problem, are you a little bit more hungry?
Where did you get your key? Are you trying to re-code the original key of the vehicle?
08.05.2020 15:04 # 17
cobut
ANKARA PROVIDED 307 CONSISTENT PRICES FOR ESATTA, 70 FOR THE REPLACED KEY, WITH 150 CONTROLS. SECURITY PASSWORD TELLS THAT ITSELF SHALL
08.05.2020 15:04 # 18
hanniball35
Yes, teacher, I asked the car to code it. I got it. The car had a 4-digit BSI code. We also supplied it from the service. I introduced the keys from pp2000.
08.05.2020 15:04 # 19
BerkayTutal
I am wondering, does the bsi code change when the tape removed from a different vehicle? Let's not have problems with the key or vehicle afterwards?
08.05.2020 15:04 # 20
There is no problem with the key, I just know that the tape's chassis number should be coded, and they will handle it for 20-30 TL.
Page : / 2
