Key chip problem .. Help please [solved]
08.05.2020 20:02 # 1
ertanakar
Friends, I lost the chip when I changed the key cover of my 2005 peugeot 206 car .. The key in my hand is starting but not running .. Auto keyers want around 350_400 lira. ertanak is 2016-11-16 09:05:21
08.05.2020 20:02 # 2
Badur
Remove the immobilizer chip as well. It works without it. Or operate with a spare key.
08.05.2020 20:02 # 3
ertanakar
Where is the immobilizer chip is a simple event I don't know where it is
08.05.2020 20:02 # 4
TugyyStyle
If the master spare key is standing, put it inside the fuse box and start it again with the normal key :)
08.05.2020 20:02 # 5
ertanakar
Sorry, the replacement key can only be used to open the door
08.05.2020 20:02 # 6
Badur
Take out the card inside the key case and operate it like that. It will likely work. You can use it this way. Of course, you need to open and close the doors from the key.
08.05.2020 20:02 # 7
monalos
[QUOTE = ertanakar] Unfortunately, the backup key can only be used to open the door [/ QUOTE]
the tool works with a spare key, the chip of the remote key slipped out of it, I tried to back it up, it worked on the biker, so I used it for 1-2 days, then I put the chip on the remote and it was fixed
If your spare key is stopping, when you take the chip inside it and put it inside the remote key, the car works without any problems, and since you get the chip in the spare key, it only functions to open the doors.
08.05.2020 20:02 # 8
ertanakar
I haven't tried the backup key before.? closed plastic, just to open the doors .. there are not even on / off keys
08.05.2020 20:02 # 9
monalos
No chip inside, have you removed the spare key and looked?
08.05.2020 20:02 # 10
TugyyStyle
My spare key is always at home, the main key is sometimes I need the house at home.
08.05.2020 20:02 # 11
monalos
What has become of using the key: D inside the replacement key, on the chip at the full end: D
monalos 2016-11-15 22:08:04
08.05.2020 20:02 # 12
ertanakar
Did you cut the spare key yourself?
08.05.2020 20:02 # 13
monalos
It is not a cut, it turns out with a light screwdriver with tabs, I searched to show it, I found the key
08.05.2020 20:02 # 14
ertanakar
I have this key too. I will cut my first job in the morning and I'm on duty.
08.05.2020 20:02 # 15
monalos
No need to hit a knife or something, it will get rid of the nail when you insert it from the junction point with a normal thin screwdriver and then pull it out, then you will have to pull that opened piece towards the end of the key and then take it out.
08.05.2020 20:02 # 16
ertanakar
Thank you very much, guys, don't get me wrong, you made me feel .. don't lose the jeep My story is so funny .. the key case is a little old. I looked at aliexpress.com for one dollar. In our shops, I ordered 25 30 lira .. came in a month .. I saw it in front of the door today, I quickly opened my feet and dumped the old one .. A few small pieces fell to the ground. gone in the old bowl I threw .. 15 20 lira profit while 300 lira was bored I was bored again for your comments Thank you
08.05.2020 20:02 # 17
monalos
Do not worry, brother sees the inside of the chip in this backup, but if the place of the chip shifts properly, it will not work as soon as I have a problem.
08.05.2020 20:02 # 18
ertanakar
Ok I hope I will do what you say in the morning .. I will not sleep anyway, I will write to you too
08.05.2020 20:02 # 19
Badur
It's in the piece you throw in the trash. You can not even see if you are looking at the corner carefully.
08.05.2020 20:02 # 20
ertanakar
I understood, but the situation has developed so fast .. Even the garbage truck came and got the garbage at noon .. It is gone .. In the morning as friends say, I will disassemble the spare key in the morning, Normally I know that it does not operate the spare key, but if there is a connection with the remote, I hope there is little
Page : / 2
