Key
08.05.2020 16:25 # 1
xpyhre
The key of my 206 is not fully seated in the ignition. / font> enters the contact up to the bottom (solid long red line). the key in the picture is exactly the same as my key ..
< / p>
08.05.2020 16:25 # 2
ose
I guess your ignition does not turn if your key does not fully enter. The mechanism inside is probably broken. & Nbsp;
08.05.2020 16:25 # 3
xpyhre
[QUOTE = ose] I guess your ignition will not rotate if your key does not fully enter The mechanism inside is probably broken. & nbsp; [/ QUOTE]
The contact is spinning, but the key is falling ...
08.05.2020 16:25 # 4
yavuz25
A hook passes through the hole in that key. If I think that hook is slipped inside the contact.
08.05.2020 16:25 # 5
xpyhre
Sir, the key must enter the ignition until I marked it with OK, right? Could I adjust this hook? I'm in the garage right now I'm dealing with contact.
08.05.2020 16:25 # 6
djchaos
the contact does not enter exactly, this may be the same in 206 as I have seen in my other vehicles, the marked place you have shown is the end of the contact, but I think the contact is not related to the key.
08.05.2020 16:25 # 7
xpyhre
If the friends who have 206 insert the key in the contact and write down how long the key is entered here, they are very welcome.
08.05.2020 16:25 # 8
yavuz25
[QUOTE = xpyhre] Sir, the key must be in contact until I have marked OK? Could I adjust this hook? I'm in the garage right now. I'm dealing with the contact. It does not even take money. But if the key enters the contact correctly, then the contact must be removed and maintained before the problem grows. If not, you will be on the road like me .;)
08.05.2020 16:25 # 9
xpyhre
can not auto electrician? & Nbsp;
08.05.2020 16:25 # 10
yavuz25
He will know how to disassemble the contact and know where it needs to be lubricated. It will wear and become lean like every piece in the contact. For this, it must be maintained.
08.05.2020 16:25 # 11
xpyhre
besides, without a key, screwdriver, knife, nail, etc., the material is turning on the contact, the tool is running, there is no need for a key ???
08.05.2020 16:25 # 12
yavuz25
of of that contact needs urgent care.
08.05.2020 16:25 # 13
xpyhre
Thanks to this contact, the starter motor burned twice 450 TL.
08.05.2020 16:25 # 14
yavuz25
You can change it. It should be sold as a set.
08.05.2020 16:25 # 15
xpyhre
[QUOTE = yavuz25] is stuck. You can change it. It must be sold as a set. [/ QUOTE]
I think the reason for the combustion of the starter motor is from the contact, the key is stuck in the contact according to the head, it starts the starter motor when going on the road. editID> xpyhre 2011-12-04 10:35:52
08.05.2020 16:25 # 16
yavuz25
The starter motor is not wasted.If you press the starter while the car is running, there is a sound of rubbing on a bitter toothed gear.
08.05.2020 16:25 # 17
xpyhre
& Nbsp; My teacher then goes to the starter gear flywheel while the vehicle is running, so the starter motor is on. can we have such an idea? otherwise, the starter motor will not burn twice. If I bought 1 new starter motor, the starter motor will burn again, as there is a problem in the contact. The starter spreads the flywheel to the flywheel. When I asked the auto electrician, he said that if there is a problem in the ignition, he will always burn the starter motor & nbsp; .. & nbsp; xpyhre 2011-12-04 11:03:02
08.05.2020 16:25 # 18
yavuz25
The idea you walked is correct. Your contact needs to be changed as a set.
08.05.2020 16:25 # 19
yavuz25
I recommend that you change the contact as a set as soon as possible.
08.05.2020 16:25 # 20
xpyhre
Brother, if I change the contact, complete ,,, I removed the old contact. .. & nbsp;
Page : / 3
