Key
08.05.2020 17:01 # 1
sipisa
Hello,
My first post in the forum. I have 308 soon. I'm about to get a clean 308 second hand. But I have a question. I bargained for a 2008 model 308. The car is clean, at 74000 km, it looks not worn. Of course, expertise etc. I'm getting. But there is something stuck in my head. I was amazed when the car owner gave the key to my hand. All vehicles in its class had an easy-to-use snap wrench, while 308 had a classic key. Is there something wrong here or did peugeot make such a mistake? I am waiting for your comments. Thank you. Reviews
08.05.2020 17:01 # 2
This is not something to follow. You can turn the solace into the key. Welcome to us. Please familiarize yourself with the link in my signature.
Good luck now.
koliva 2012-09-02 21:59:47 < / edited>
08.05.2020 17:01 # 3
SZKR
Whether you have 308, this is your only problem. Do not worry, you will have a little switch with a snap switch (: Good luck ...
08.05.2020 17:01 # 4
tellotello
Whether the vehicle is good, it is clean, well maintained, without a switch, teacher. Never mind the key (I think, of course, & nbsp; "Smile" & nbsp;). You get it done in 2 days. Hopefully it will be a tool as you wish. Best regards.
08.05.2020 17:01 # 5
dukenukem82
They handle it with a small fee, if it is on the central unlock button.
08.05.2020 17:01 # 6
maydogan67
hello I have a 206 xt 2001 model vehicle, I have a big problem with the central lock. When I press the unlock button from the key's control, it does not work when I try to open the key (only from the front left or right). When they closed the contact, they held down the control of the key, they fixed the problem, but later it started to do it again.
08.05.2020 17:01 # 7
pierson
my door is opened automatically, but when it comes to grabbing it is not closed remotely ... manual is closed ... what should I do?
08.05.2020 17:01 # 8
sezar206
[QUOTE = maydogan67] hello I have a 206 xt 2001 model car, I have a big problem with the central lock, when I press the unlock button from the key, it does not work when I try to open the key, it is locked in the trunk since there is no luggage key, I took it to the repair under the steering panel. they removed the fuse and put them on, they started the car and closed the ignition, they held down the control of the key, they solved the problem, but later started doing it again, I was doing what I learned, but now it is completely broken. Do you have any information about this issue? I forgot his name, but I recommend that you go and have a young man look good master.
08.05.2020 17:01 # 9
maydogan67
08.05.2020 17:01 # 10
maydogan67
thank you I was able to write a little late & nbsp; but the masters can not do anything about this topic I took it to another recommended master this day, they said that he knew everything about peugeot electrician but could not understand the room they say there is a problem in the brain but I think they can not find a short circuit somewhere ... I hope I will relax if there is a key room ...
