Kararan Indoor Lighting
08.05.2020 20:48 # 1
ORhun53
Hello friends;
As of yesterday, when turning on the headlights of my vehicle, mileage indicator lights, trip computer and air conditioner lights are getting weaker.
The battery of the car is new Varta 70 amperes. My car is 2006 Feline model.
I'm waiting for your help.
08.05.2020 20:48 # 2
oguzhan53
Next to the headlight height adjustment on the left side, there is a lighting dimmer that is likely to be dimmed.
08.05.2020 20:48 # 3
ORhun53
Sir, beside my headlight adjustment, there is a button to open and close the airbag, and a button to lock the rear windows.
08.05.2020 20:48 # 4
oguzhan53
Then there should be a button like km reset button, hold it on the dashboard, the lights increase and hold again, decrease.
08.05.2020 20:48 # 5
ORhun53
[QUOTE = oguzhan53] Then there should be a key like km reset button, hold it in the dashboard, the lights increase and hold again, decrease. [/ QUOTE]
My teacher tried it at the last light intensity. As long as I do not turn on the headlights, the light intensity is already at the highest level.
08.05.2020 20:48 # 6
oguzhan53
When the headlights, which are played with the dimmer setting, are turned off, the full light will be dimmed when the lights are turned on to park or dipped beam. Have you tried while the headlights are on, when the headlights are off, that key is not active, try when the headlights are on, it will be leveled. oguzhan53 2018-03-14 00:06:09
08.05.2020 20:48 # 7
TugyyStyle
Good luck, if the charger is not working, it is not working, if there is no problem, the charger is defective. In other words, if the summary does not work at night, there is no problem in the charger.
08.05.2020 20:48 # 8
ORhun53
[QUOTE = TugyyStyle] Good luck, the charge dynamo is out of order if it is not working while the charge dynamo is defective. In other words, if the summary does not work at all, there is no problem in the charging dynamo. [/ QUOTE]
My teacher has the problem when it is not working. When I work, when I turn off the headlights, the trip computer and the air conditioner light goes up and the headlight decreases as I turn on the headlight.
08.05.2020 20:48 # 9
ORhun53
Thank you guys for the help of all of you.
The indicator light intensity of the vehicle does not fall when it comes to the very end. Unless it is at the highest level, the light intensity decreases when the indicator lights turn on when the headlight is turned on.
08.05.2020 20:48 # 10
KILIC
Sir, this is normal. He cuts himself down so that you don't take your eyes off at night. There is nothing to be afraid of
08.05.2020 20:48 # 11
onlycihan
you will forcibly disrupt the robust mechanism Smile It works as it should. Thumbs Up
08.05.2020 20:48 # 12
Furkan979
A feature in these peugeots is that when you turn on the headlights, you can adjust the settings if you hold the button next to the km adjustment button daily so that the screen gets narrower.
08.05.2020 20:48 # 13
ggitaristt
You have read all the messages to me in vain ..
I thought there was a problem ..
I'm leaving without incident .. Big smile
