JUSTICE OPERATION IN COLD WEATHER
13.01.2022 14:00 # 1
AEKARABULUT
HELLO
2005 2.0 GASOLINE NO LPG AUTOMATIC THERE IS 407 THESE TIMES IN COLD WEATHER WHEN I STARTED WORKING IN THE MORNING, IT STARTED TO WORK jerkily. WHAT MAY BE THE REASON
14.01.2022 10:57 # 2
Hello .
The problem probably sounds like a coil spark plug, sir. What was the last change?
16.01.2022 12:38 # 3
AEKARABULUT
hello
I renewed the spark plugs 6 months ago but I never changed the coil
17.01.2022 16:02 # 4
Sir, if there is no lpg, the reasons for it to work late and be jerky.
1-spark plug and coil
2- fuel filter
3-gasoline injectors
4-crank sensor
5-engine and transmission mounts
10.12.2022 15:02 # 5
Toprak46
Did you find a fault?
