Junyan angel ring led help?
08.05.2020 18:33 # 1
olkannn
friends junyan angel leds of one of my headlights led off. my electrician couldn't find it everywhere (edirne) and finally took the led and let it be done by doing it, but they went out in a week. now their leds are referred to as t-shaped leds. Is there any friend who knows or can send these leds? these are the leds
08.05.2020 18:33 # 2
Alicilik
This is the first time I have seen this LED. There is certainly who knows where to find it. We need to look abroad.
08.05.2020 18:33 # 3
olkannn
there are only foreign sites. ebay etc. we couldn't find any of them on the site. junyan angel headlights are ring leds Smile
08.05.2020 18:33 # 4
Ahmet_ach
Brother, I had such a problem. These LEDs are 1.5 volts. So there is a small transformer that adjusts the voltage of these LEDs. 12v `tu lowers 3 volts.
08.05.2020 18:33 # 5
olkannn
Which LEDs should I buy from 12 volts? Can I put it there because the tip of this t shape led is like a fork?
08.05.2020 18:33 # 6
DeRyCK
I have that same problem. I bought 3mm led and made it myself, I also connected the resistors but it was not very efficient. Deflated burned, exploded again, etc. The most definitive solution is to buy from foreign sites but it is very expensive.
08.05.2020 18:33 # 7
olkannn
friends today i talked with aksoy tuning i got the headlights, they will send it. I will inform you again after I receive it.
08.05.2020 18:33 # 8
DeRyCK
Is Aksoy tuning in Güngören, Istanbul? What did they say in price? I would be glad if you can give information.
08.05.2020 18:33 # 9
olkannn
I don't know where the place is, I probably got there by phone. They asked for an address, they said we would send, they did not say anything yet. but even if he says 50 TL, he will not have any other place because Confused
08.05.2020 18:33 # 10
DeRyCK
how many leds did you want? If you want 1, 50 TL too :) I need 4 :)
08.05.2020 18:33 # 11
olkannn
No, I wanted 2 I have 25 Smile
08.05.2020 18:33 # 12
DeRyCK
a little more convenient Smile When you reach your hand, you inform us
08.05.2020 18:33 # 13
impact
I tried very hard. I did not find white because I did not find white, I removed the whites and connected the yellow led myself. I used it for 2 months and then started to go one by one. I bought another model led from ebay, opened the headlight interior, expanded its slots and put it on like a monster.
08.05.2020 18:33 # 14
DeRyCK
It was very good, it was very affordable. Easy to expand slots, how to shine?
08.05.2020 18:33 # 15
impact
lighting is good but not like a fluorescent ..
It is better to install a fluorescent angel when opening the headlight inside to open the headlight inside to do two socket expansion work. If you say I will use your own angel rings, sanding the rings with 600-800 grit will be more obvious.
08.05.2020 18:33 # 16
Alicilik
Could a 5050 solid smd be buried there?
08.05.2020 18:33 # 17
DeRyCK
There are covers under the headlight, I removed the leds from there, will I not wear them? Is there a need to open the headlight inside?
08.05.2020 18:33 # 18
olkannn
friends leds reached my hand today and i got them working right now. But I do not work with LED accessories, now I got infected for the first and last time Smile
08.05.2020 18:33 # 19
DeRyCK
Enjoy it Smile
08.05.2020 18:33 # 20
olkannn
thank you Smile
Page : / 2
