Junyan Angel Headlight Ring Exchange?
08.05.2020 18:18 # 1
Piyanist89
friends today i got 2nd hand angel headlight. I just realized that the angles of the right side are burning white, the left side is a little dark blue in the picture like blue. but the other is vivid white and the other is a little dimly, not slightly in full white but from mild to blue. can we change this ring? how much prices? and the headlight screw or is it intentional opening with a screwdriver? I am happy if he writes with knowledge.
Piyanist89 2014-02-16 01:28:20
08.05.2020 18:18 # 2
reality59
My master, as far as I know, you need to warm the headlight and prove it with a screwdriver, remove it completely and change the ring inside or change the led inside the ring. reality59 2014-02-16 02:27:55
08.05.2020 18:18 # 3
Piyanist89
while my father was wearing them, there were bulbs under the rings, they could change without removing the glass. I wonder if I just change the bulbs? or will it be ok if I wear the bulbs blue or other color instead of white?
08.05.2020 18:18 # 4
Piyanist89
http://img593.imageshack.us/img593/5388/13608134.jpg
I guess it is not sold as ready-to-sell as it is with the sense. I will take just the light bulb like this picture.
http://img220.imageshack.us/img220/7797/23248627.jpg
I think it is true that I will remove the solder on it, shorten the legs of the bulb I bought and find and solder the plus and minus.
Piyanist89 2014-02-17 00:24:00
08.05.2020 18:18 # 5
DeRyCK
Are we able to find the leds in this way? I soldered the same way, the leds exploded, I connected the resistor and burned it was very dim. What should be done to make it burn bright and long lasting?
08.05.2020 18:18 # 6
DeRyCK
I'm talking about the leds connected in T shape. It exists in foreign sites but comes at very cold prices.
08.05.2020 18:18 # 7
DeRyCK
T shape led is on the internet. I want them to burst and change them all and make them shine brighter.
08.05.2020 18:18 # 8
DeRyCK
My headlights are junyan. As I said, I soldered the LEDs exploded, I connected the resistor and burned it was very dim. I used 3mm narrow angle leds. How many ohms of resistance can I use to achieve maximum brightness?
08.05.2020 18:18 # 9
DeRyCK
:) I do not know that much, I blew all the leds :) Thank you for your help. It seems more reasonable to have it done in an electrician
