Jumping into 1st and 2nd gear transitions
08.05.2020 19:18 # 1
wesser12
friends, I had LPG on my vehicle 1 month ago. As the gear shifts, the vehicle jumps like a novice ride and takes a knock-off. there is no problem in other gears only in 1st and 2nd gears. Also, the tachometer sometimes plays around, it seems as if it gives light gas at idle between 0.8 and 1.2. He said to the gas worker that it was not from the gas.
08.05.2020 19:18 # 2
wesser12
The problem is solved. The lower ear is gone, changed. Jumping is over. LPG has been solved with the installation of a new version that has broken the settings of the brain, no problem
08.05.2020 19:18 # 3
ramazaneminaksu
I have the same problem. knock off but there is no problem in the tachometer.
the knock off is stopped after a while. Did it coincide with a hump during the knock off, as if something was shaking at the bottom like idle, I couldn't figure it out.
08.05.2020 19:18 # 4
ramazaneminaksu
the transmission ear is broken, I will replace it.
08.05.2020 19:18 # 5
ramazaneminaksu
I also changed the ear of the gearbox, thank goodness is over.
