Jerky Operation and PP2000 Test in Cold Engine
08.05.2020 21:19 # 1
x571
I have a problem with jerky operation when the engine is cold in the morning. It doesn't do that all the time. He does it once a month or two every month. There is no explosion from exhaust or movement at the tachometer during the shaking. the problem goes off when the ignition is turned off and on and it doesn't do it again I had a problem with the coil 6 months ago. I replaced the coil with a delphi brand. spark plugs changed to 12-15 thousand km the vehicle does not have a spark plug cable.
when i encountered this problem i bought lexia cable to use pp2000. error code as p0300 looks.
I did a test on pp2000. what does this test tell us?
[TUBE] 8wjqqxjp434 [/ TUBE]
It is not clear in the video, but two of the green spots in the bottom right corner have become red in a part of the test. what is the reason of this ?
Also ; I was not satisfied where I got the cable. There were more tabs in youtube videos, I only have error reading, error deletion, test and one more section.
When I update the program, the automatic diagnostic feature of the vehicle says something like the automatic diagnostic feature of this vehicle has been turned off. why does this happen?
He did not give me the passwords that he should have given during the installation, and I did not ask for 300 lira support money. I will return it because I got it from the internet.
Does this cable have good quality? how to understand who should get it? Would it be a problem if I buy it from alibaba? do you know a reliable seller?
x571 2019-09-25 11:40:24
08.05.2020 21:19 # 2
x571
the subject is up to date. Those with knowledge are expected to help.
08.05.2020 21:19 # 3
Orcun.Dmr
Sir, I'm sorry, sorry, it's not relevant, but from which sites can we download and install PP2000 on the computer? I am thinking of buying the cable as a set from aliexpres.
08.05.2020 21:19 # 4
x571
[QUOTE = Orçun.Dmr] Sir, I'm sorry, sorry about the issue, but from which sites can we download and install PP2000 on the computer? I am thinking of buying the cable as a set from aliexpres, there is a cd or something, I don't think it is a cd to install pp2000. [/ QUOTE]
I do not know much, you will find the program from Torrent, but the story is also cable. The man you already bought the cable also gives the software. The important thing is that it provides free support and I am not satisfied that I bought it from a Turk.
08.05.2020 21:19 # 5
x571
