IZMIR STEERING REPAIRER ADVICE
29.06.2020 09:19 # 1
ozandemir34
Friends, I have a 2005 model 307 1.4 hdi vehicle. My vehicle also has a problem of disabling the steering fluid, which was initially on with the air conditioner, but lately started to do constantly. At first I changed the 70 amp and 10 amp fuse in the fuse box, but it didn't improve. Now it does even if I don't turn on the air conditioner. As far as I learned from friends who had been in the forum before, the oil dripped on the card in the steering pump, and it lost its function over time. The electronic card had to be repaired. Is there anyone in Izmir who knows a steering wheel who can fully help me? If there is anyone who has it done recently, I will be glad if you can help.
29.06.2020 10:13 # 2
Unfortunately, I don't know, teacher. But the last one was around 400-700 TL in the last 1 year, probably around that.
01.07.2020 23:15 # 3
ozandemir34
Today, I had to put the original oil, "total fluide," into the vehicle. The steering wheel of the vehicle became noticeably soft, but the hydraulic was disabled without driving for 10 minutes. According to its own mind, it works in 2 or 3 contacts, the room lasts for 20 minutes at most and then turns itself off. I received a price for a revision of 1400 TL from someone who repairs an electric steering wheel, and as soon as 80% is repaired, we will have to install the zero at 2200 TL, I will only get the difference. Do you think the prices are normal? If I go to normal steering wheel, I expect your help if they can help.
02.07.2020 08:34 # 4
ismailkaya
The steering pump is being repaired. If you were in Bursa I would have helped. I think it seems like there is a simple electrical problem if it comes on and off. Check the electrical sockets before you go to the steering wheel. If you take it to the steering wheel to see if there is a place of oxidation, lack of contact, the pump will be deactivated from time to time.
09.07.2020 20:29 # 5
ozandemir34
Brothers also made lathe in İzmir Bornova. He said that if he could not save 400-700, he could wear 1200 TL and the original could cost 2200. Mine cost 700 TL, he said, the integrations are broken. He said that if it breaks forward, he can change it with its release and only take the difference in between. Now there is no problem, thank God, it was a click softer than before, it does not matter much compared to the normal hardness, but now there is no hardening like a tractor steering wheel. Brothers lathe Aykut, if you ask me to recommend the master, I can yes because of his sincerity. Ozandemir342020-07-09 20:34:05
