İZMİR - SIGNAL ARM REPAIR HELP
19.10.2020 11:20 # 1
ozandemir34
Hello everyone, friends, I have been suffering from the chronic problem of the signal arm malfunction in my 2005 model 1.4 hdi 307 vehicle that I have been using for about 3 years. Although I did not care much before, I now consider getting it done. When the signal lever gives the right signal in the vehicle, it automatically returns to the left when it collects the steering wheel. When the headlights are on, there is a situation like I cannot give any signals. With the headlights off, I can give the signal without much difficulty, and sometimes it happens that the horn does not sound after signaling with the headlights on. In this case, I turn the headlights back on and off, so the horn is activated again. Also, if I pull the long ones too hard while burning, they become active and unfortunately I cannot get them back to the short ones and I turn the headlights back on. If there is an electrician in Izmir that I can find a solution to this problem, and if there is someone in other cities to fix this problem, I would like the help of my friends who can tell how much it costs.
19.10.2020 16:39 # 2
emirksk
This is the broken part, if you call the internet for comm2000 repair, a video explanation comes out. but a little difficult. https://www.aliexpress.com/item/4000042145740.html If there is no hand predisposition, get the complete handle.Install it to the electrician.https: //www.aliexpress.com/item/32853638263.htmlya you will find a man who has already dealt with these things that izmir` There is not much of a possibility. or there will be methods I said. Do not look zero handle is too expensive. Visit the makers and buy if there is a problem for 300-400 TL. Otherwise, it would be the most affordable way to bring it from China. nevertheless, visit the industries and get information, maybe the people who do. My first advice is 3. There is a mileage leader in the industry An electrician specializing in psa. I do not know how to give advice, but it will show a way. 2. industry french auto ali koç master there are mechanically craftsmen, but there are a lot of electricians, you can get an idea from him. There is Volkan Öztürk Otomotiv at Salhane İzban Station and PSA Special Service. I don't think they will, but I think they will help. there is iztek pejo, there is ayhan oto in cigli. These places I mentioned are basically peugeot masters, and from time to time I was satisfied with my job so I wanted to write it as an advisory. If you do not get results from these places, you cannot get them from anywhere emirksk2020-10-19 16:45:13
20.10.2020 14:34 # 3
ozandemir34
Thank you for your information, if the weekend is fortune, I will go to meet with these places. I hope I can find someone who makes it affordable.
21.10.2020 00:56 # 4
emirksk
[QUOTE = ozandemir34] Thank you for your information, if the weekend is fortune, I will go to meet with these places. I hope I can find someone who makes it affordable. [/ QUOTE] I hope you find a solution, sir. Please inform the result that it didn't happen to me, but one day, of course, let's consult there.
24.10.2020 22:59 # 5
Brcbyrktr
I had the problem of the Signal Headlight arm you had In addition, the headlights turn off during night trips for a short time, etc. I did a lot of research for its repair, but nobody approached. It is a matter of luck how strong it will be in the second hand .. When the days are getting shorter, I did not leave it to chance and found the compatible arm in the pejokar. I can easily signal left and right.
25.10.2020 12:41 # 6
B7e7
Slm, I had the same problem, the signal arm changed. If you put 150 TL on the steering wheel yourself, or you can do an electrician with a workmanship like 50 100 TL.
25.10.2020 12:42 # 7
B7e7
I have a spare arm, I can send it.
12.06.2025 13:02 # 8
Sorgum
Repair is possible with diligence and care. For assistance, please contact us using the signature section below. https://www.ugurotoelektrik.com.tr
