It works directly with LPG in the first operation.
28.06.2021 16:52 # 1
x571
I have such a problem. The vehicle starts with gasoline in the first run. After 10-15 seconds, the shaking starts, the engine seems to stop, the rev counter moves a little and switches to LPG. While this is happening, the engine is still cold.
it works again if you manually switch it to gas later.
lpg
We changed the LPG regulator completely, including the heat sensor and gas breaker.
28.06.2021 19:48 # 2
muzzy35
My teacher probably tried it, but when adjusting the LPG brain, there is a transition temperature to LPG, even though the engine temperature is low because the weather is warm, it reads high. I recommend you to increase the transition temperature to LPG to 50 -55
28.06.2021 19:55 # 3
x571
this conversation existed in winter. At the first start of the day, the engine seemed to suffocate and staggered, then switched to LPG. While this is happening, the engine is colder. We changed the LPG regulator thinking that it was leaking gas because it was leaking water, it had been 8 years.
28.06.2021 23:32 # 4
talip206
Sir, 90% lpg is due to transition temperature settings. Have at least 40 45.
There is also another setting. Even if the heat is high, so that it does not pass immediately. 5 seconds vs 10 seconds. setting is in progress. Let's say you moved and the engine warmed up. Then you stopped. When you start it again, you can adjust it so that it does not immediately switch to gas. It better be a little late too.
Check these two settings.
29.06.2021 08:51 # 5
x571
ok thanks sir. It didn't work, they sell the cable for 100 liras, let me buy it and make it in the garden.
