it was time to deal with cars
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 18:33 # 1
zr`lmn
May it be easy for all of you. I have owned 307 for about 3 months but due to the rainy weather, I could not deal with a tour. Previously my car was 99 focus tu. After that, when I got 307 thousand, this car came perfect :) I heard the classic problems that everyone heard and I was very afraid but I bought it because I took it from my friend. After receiving the mileage, I have already done 110 thousand maintenance by all the heavy maintenance service. I have a few questions in my mind.
1. There is a slight wetness on the ground side of the driver, but there is no shortage of vehicle water (as far as I searched, I will clean the air conditioning drain hose at the first opportunity)
2. There was no headlight adjustment officially, I was going to go to the right, I knew that the right headlight adjustment engine would be replaced, but I couldn't change it.
3. One of the bulbs that illuminate the plate is defective so I inserted the bulb's housing, but I could not remove the bulb and how to remove it and what type of bulb is needed.
4. As the vehicle passes through the weed wheels, the sound comes from the back (it was coming from the rear wheel, the damper casing was placed on it and the sound was cut off)
5. I am a bit afraid that the electrical system is called gentle. For example, if I make an American parking system, will it cause any problems?
6. I live in Mugla Yadangan. Is there a known master in Yagan or Mugla Center? When something happens to us, we can go directly to it.
(I will upload vehicle photos as soon as possible)
For now, thank you so much for your reply.
08.05.2020 18:33 # 2
Alicilik
First, welcome. Use your vehicle bye. Don't let the 307 or pejo scare you. A properly looked and used vehicle does not easily upset a brand. But still he does not want a little more attention and care, but gentle and sensitive tools.
If we come to your questions,
1. As you said, there may be a problem with the evacuation, but a situation in many vehicles.
2. If you could remove the headlight, your job would be easier. Because the headlight height motor is mounted and turned at a certain angle.
3. Plate bulb t10 is bottomless. You can also do it with an intervention from the front without removing the back protection cover.
4. The suspension system is soft and gentle. The front set is sensitive in the same way.
5. I did it on my own vehicle, I did not have any problems. There is no problem when you do the operations properly. Since it is a chassis, you do not have any trouble since it is short-circuit and insulated work is done.
Unfortunately I can't help about the subject. It is good to say that I am in Ankara and do not know any place other than Ankara.
Expect detailed photos: D
Have a nice day.
08.05.2020 18:33 # 3
zr`lmn
Thank you for your help. When I say intervention on the side for the plate bulb, do I have to insert the plastic parts in the trunk?
08.05.2020 18:33 # 4
Serkan
You have reached the plate bulb, as far as I understand, grab the bulb and pull it out directly, there will be no claws or anything.
08.05.2020 18:33 # 5
zr`lmn
There is a problem in the water, and when I go with LPG for 3 days, the mixture of gasoline and diesel oil creates a smell inside the car. Does the water coming from the air-conditioner gas smell like that?
08.05.2020 18:33 # 6
Serkan
Could there be an antifreeze smell?
