It was the first time I was on the road.
08.05.2020 19:07 # 1
206cc57
Hello, my 206 cc 2004 automatic gearbox is at 130000 km .. I have done all the maintenance regularly except for the trigger change. I had a trigger change plan before the summer, just before my vehicle was stopped, I suddenly stopped, fortunately the steering wheel and the brake approached completely before it hardened. First, I bought gasoline, but it says gasoline in the gas plug and I saw the green pump, my family thought that they accidentally put the diesel.
I opened the hood in the dark, couldn't see anything abnormal, can I understand if the trigger was broken?
Also, my car will be automatic, will it be necessary to get from P `to N while loading the tractor tomorrow? If yes, could I get it with the ignition off? I have never tried.
206cc57 2015-02-25 20:12:37
08.05.2020 19:07 # 2
koray.turan
Have you entered the hole that came to my mind at the simplest moment?
08.05.2020 19:07 # 3
206cc57
No, on the contrary, the road is E5 style flat asphalt, I used 50 km before fueling, the engine was hot as information, but it was not enough to be hot. My anti pollution light had gone on long ago and went out by itself, but the antipollution had been on for about 2 weeks.
08.05.2020 19:07 # 4
talip206
When pulling the vehicle, definitely and definitely take it to N and do not exceed 50 km (when pulling with rope etc.), the gears can change without starting the vehicle.
talip206 2015-02-25 20:29:48
08.05.2020 19:07 # 5
sezar206
First of all, the vehicle has something like a red cover on the right side of the bonnet. The vehicle does not stop and start when it has a negative situation. Have you tried to run that red button and run it?
08.05.2020 19:07 # 6
koray.turan
Press red behind the battery with impact sensor
08.05.2020 19:07 # 7
206cc57
Thank you very much for the information, before I read the above, we went to the car with my brother once again, it didn't work again, I'll definitely try it before talking to the tow truck tomorrow. By the way, the starter motor turns the engine but there is no ignition, not the trigger. We smelled gasoline in the fuel I bought, I checked the plug, absolutely petrol in my pump memory. It is not a pit on the road, but I came to the right about 15-20 seconds before the engine stopped, I braked a little harder than usual, I had a van in front of me, could it have affected the impact sensor .. If I can find time from work tomorrow, I will look at the impact sensor.
08.05.2020 19:07 # 8
Efe-Pojo
I hope it is not a timing, but how did you know it was not?
08.05.2020 19:07 # 9
talip206
Well, I suspect the timing. I think don't push too hard can lead to bigger problems if there is no tool
08.05.2020 19:07 # 10
koray.turan
Since I have an impact sensor, I could have a hard brake. Get well soon
08.05.2020 19:07 # 11
Alicilik
If yahu is a triger, the engine will be pert as far as you tell. I think he has another problem. Did you enter the network in water or did you get any error related to immo?
08.05.2020 19:07 # 12
blntctn
[QUOTE = Buyer] If yau is a triger, the engine will be pert as much as you described. I think he has another problem. Did you enter the network in water or did you get any error related to immo?
You are absolutely right, immobilizer came to me at once without any error in fiat albea in me, but I was parked aside for 2 minutes when I was not going, it was not working then it was not working but it was not working, of course, the coin was dropped when I called the service.
08.05.2020 19:07 # 13
206cc57
hello thank you all again, I started this day by doing a secret escape from my job so that I can deal with my car .. I suspect the immobilizer because I turned the key into a switchgear one month or a while ago, the imbbolizer error appeared on the screen and the keysman boy apologized for the first start because they did not insert the immobilizer into the remote control. It was very intense, but there was little doubt that it did not appear on the screen. I tried it not working on the impact sensor .. and I went to the service using my free tow right with the service provided by the narrow fuse. It was trampled and feared. Trigger strap was broken ...
A master said that a 5% probability could not damage the valves, a new belt was tried, but it did not work. They said that they would probably start the process by removing the cylinder top cover. It will cost around 1500 - 2000 TL.
I am the only responsible for this incident, because in July, the master asked me the trigger in maintenance, I told him that I did not change the car for 4 years, I did not change it, I knew the old owner, I asked him .. I asked, I did not change it. It was ... I wish ...
08.05.2020 19:07 # 14
206cc57
http://i.hizliresim.com/8lzdqa.jpg
Triggered photo 3 and 5.
206cc57 2015-02-26 15:43:32
08.05.2020 19:07 # 15
koray.turan
Get well soon
08.05.2020 19:07 # 16
206cc57
thank you so much .
08.05.2020 19:07 # 17
trabzonlu207
[QUOTE = 206cc57] thanks a lot.
[/ QUOTE] my brother has a lot of history ..
08.05.2020 19:07 # 18
erdemchetin
my brother get well soon
08.05.2020 19:07 # 19
baybaba
Get well soon, how to tell if a car's timing belt is broken, after all, most people, your friend
he tries to start the car that does not ring as he did, in which case he will accidentally damage the engine.
is given, is this strap visible when we lift the hood, for example the partner's engine from above
I see a belt, but I don't know if this belt is a timing belt,
08.05.2020 19:07 # 20
206cc57
Thank you very much, I hope that it will not happen to anyone, the hardening of the steering wheel and the brake after it istop on a road where traffic flows is dangerous.
All of the masters asked if they tried to start it, did they start? because they said it hurt, i said i tried to run it of course .. when i got off the hammer the master started the starter .. then he connected it to the computer. also
When I opened the bonnet it was evening and there was no abnormal smell. He suspected that the master was stripping or breaking first.
Page : / 2
