It was necessary to drive 307 fast ...
08.05.2020 15:05 # 1
ereneren
friends 2005 automatic 307 owner I use low speed in the city, it burns almost 50 cents because it is less, I traveled between 110-170 on the intercity road on the road between Istanbul, Eskişehir, Eskisehir, Istanbul. I made a road in the city 700 km ...
Normally, when the tank was full, it would go between 450 and 480. The automatic vehicle did not fall under 3500 cycles since it was 4-speed. SırıtmaSırıtma
08.05.2020 15:05 # 2
ereneren
meanwhile the vehicle is at 87000
08.05.2020 15:05 # 3
BAHTIYAR
I tried and did not keep it in me. In an interchange between Ankara and Sungurlu, I went to 120- 150 at the return, the gas was finished at 280km at the village / I even came to 90a at a time.
08.05.2020 15:05 # 4
naksi
In my vehicle, I use 2004 automatic poetry lpg gasoline massallah low speed
but I went to an amasya last night I couldn't believe from Istanbul, I went 420 km with lpg 80 lira.
I did not fall down from 120-130.
does not fall below 300 cents in the city
08.05.2020 15:05 # 5
Haksen016
I have the same 306 auto in me, I have never seen it burn down from 400, I am an enemy of gasoline, but I still love my car :)) what should we do?
08.05.2020 15:05 # 6
BAHTIYAR
I am satisfied with the fuel, the gearbox annoys me, it does not change the full gear when it gets warmer in the traffic, it does not change the full gear, it will shout as if it is left from 2 or 3, but it does not go, it does not accelerate, it is 4, it still stays in the grip again, when I go to 70, I am close to 3 thousand revolutions. stop for a long time, it is like this when you use it in the city, usually it goes normally.
08.05.2020 15:05 # 7
[QUOTE = BAHTİYAR] when I am satisfied with the fuel, the gearbox is bothering me, it does not change the full gear when it gets hot in traffic. the swing bar is swinging, it just happens when you use the car for a long time to stop and get to the city. It usually goes normally. Let's get your comments.
I have a similar situation, but it seems to remain in the grip in the 2700/3000 rpm range only in the morning when switching from 1 to 2. It gives gas to itself, revs up, then shifts up, but no knocking. No problem with other gears. Thank goodness like saz.
08.05.2020 15:05 # 8
ereneren
knock was doing it in my car, stop and get too heavy in traffic when passing from 2 to 1, it was making a loud sound like tak tuk.
ereneren 2011-02-13 21:47:13
08.05.2020 15:05 # 9
BAHTIYAR
[QUOTE = ereneren] [QUOTE = BAHTİYAR] When I am satisfied with the fuel, my gear is boring, it does not change the full gear when it gets hot in traffic. When pulling, the roll bar is shaking between 1 and 2, just stop the car for a long time, it is like this when you use it in the city. It usually goes normally. Let us get your comments.
[/ QUOTE] no knocking in my car I changed the oil periodically without this complaint / occasional grip is happening. Anyway let's go until I get bored due to solenoid
08.05.2020 15:05 # 10
mendirek
Brothers tried to burn less than the truth, but the traffic cops passed 400 lira per kilometer when the traffic police wrote 270 TL and the car burns less at the lake.
08.05.2020 15:05 # 11
ereneren
[QUOTE = breakwater] brothers tried to burn less than the truth, but when the traffic cops wrote 170 TL at the lake with your car burning less, the fuel consumption exceeded 400 lira per kilometer. [/ QUOTE]
the death of the horse is from barley Göz Kırpma
08.05.2020 15:05 # 12
g-demir
Gülme [QUOTE = breakwater] brothers tried to burn less than the truth, but when the traffic cops wrote 170 TL at the lake with your car burning less, the fuel consumption exceeded 400 lira per kilometer. [/ QUOTE]
Göz KırpmaGülme
08.05.2020 15:05 # 13
she is beautiful too :)
punishment for fewer burners :)))))))))
08.05.2020 15:05 # 14
teknikerrr
I went 3 times at different times between ist.-Aydın
1- I generally used between 2500-3000 cycles without getting tired of the road on the road.
In total, Aydın Istanbul burned half a half of diesel fuel each time for 650 km.
my vehicle 2005 307 1.4 HDI fuel tank 60Lt.
In the city, I got full at the beginning of this month, 750 km so far, there was no more light.
After all, every beauty has a flaw. The lion smells of diesel but it doesn't walk. Sırıtma
