It throws white smoke only after 100 km/h
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Bipper tepee
01.02.2024 15:20 # 1
Kmltsn05
2010 Bipper vehicle only goes downhill at speeds over 100 km/h without accelerating. When you lightly touch the gas, it emits white smoke. When I give it gas, it stops. Only when you lightly touch the gas and it is over 100 km/h, they connect it to the computer. There is no error. We can't find it. Has anyone experienced something like this?
02.02.2024 10:04 # 2
Berkay Erdinc
[QUOTE=Kmltsn05]2010 bipper car, only downhill at 100 km/h and you go downhill without accelerating, it throws white smoke. It stops when I give it gas, only when I touch the gas slowly and above 100 km/h. They connect it to the computer. There is no error, we can't find it. Has anything like this happened to you?[/QUOTE]The color of the smoke is very important. White smoke is emitted from the exhaust as white smoke when the coolant enters the combustion chamber. In short, we can call it water vapor. Check your coolant to see if there is a decrease. After the car warms up, there is a wear and tear on the pressure seals in the cooling system. Although they do their job when the pressure is low, they may not be able to withstand the increased pressure. Therefore, after the car warms up, coolant may enter the combustion chamber due to a small damage in the seal. When you press on the gas, the circulation pump rotates faster with the power it receives from the crankshaft, which means more pressure will be created. Again, the EGR is cooled by coolant. A fault in this part can cause the coolant to leak. from here it can mix into the combustion chamber
