It started to bother me 307 [xx (]
08.05.2020 15:04 # 1
gozem
It takes about 3 hours, when I want to start my car
the vehicle did not start even though i started (307 1,6hdi110ps2004)
After a bit of tampering, we saw that there was no diesel coming to the engine, and we called our username to see it. He said that the pump inside the tank did not function
The vehicle remained at the door of my house.
Now we will call the hammer.
I wonder if anyone has price information for this piece.
- If I connect it to another car, would I have problems with the industry?
08.05.2020 15:04 # 2
drxugur
Hello Friend. I have many problems in 407. it has not been 15 days yet. but in my previous vehicle, the gas pump was burned out (99 passat). They changed it to 260 TL with a new one. probably yours this much (of course it was not an authorized service). Keep in mind that vehicles' fuel pumps cooled themselves with the fuel in the tank. so they said it would burn if you used less than 1/4 of fuel for a long time. Get well soon.
08.05.2020 15:04 # 3
gozem
I had little diesel, but not enough to light up.
Believe me, I have been in a thousand so that the car will not malfunction.
Let the car, summer come, polish and car for sale.
08.05.2020 15:04 # 4
06ef
[QUOTE = pug307_26] [QUOTE = car, summer come, lacquer and car for sale.
same here Evil Smile
Towards summer, I am really tired of my 307 substitute bye ...
08.05.2020 15:04 # 5
BUBU
bro, i believe i didn't see a car with 307 problems .. even a 90 hawk is not so problematic
08.05.2020 15:04 # 6
gozem
I agree with you exactly.
08.05.2020 15:04 # 7
307P
Have a little exaggeration in friends, get well soon?
08.05.2020 15:04 # 8
diabolicfb
Yoo, they are not exaggerating just by looking at my signature, it is obvious how expensive it is, what are the things that I have not done;
- noise from engine belts in the first run.
- Whistle sound when the air conditioner is on.
- the air conditioner does not work from time to time
- left signal that does not work for more than 10 minutes ... etc.
08.05.2020 15:04 # 9
Eyup Duygun
The signal arm, the com2000 part, is faulty in the 307s. Whoever owns it at the time of service is the first. Called all to change. It's free, but there is no change.
08.05.2020 15:04 # 10
307P
[QUOTE = EyupD] Signal arm, the com2000 part is faulty in the 307s. Whoever owns it at the time of service is the first one. Called all to change. It's free but has changed, has not changed .. [/ QUOTE]
I have a chronic problem as well, after giving a signal to the right and turning, do you sometimes need to change the part you say to the left?
08.05.2020 15:04 # 11
If it is such a problematic car, do not buy it and do not stain it here. then go get yours
08.05.2020 15:04 # 12
Eyup Duygun
It can be both physical and internal problem.
[QUOTE = 307P] [QUOTE = EyupD] Signal arm, the com2000 part is faulty in the 307s. Whoever owns it at the time of service is the first one. Called it all to change. It's free but there is no change. [/ QUOTE]
eyupd 2011-01-31 14:04:12
08.05.2020 15:04 # 13
metin
I have such a signal, it is chronic.
In time, Peugeot has collected all 307's and changed them back. but of course there were those who did not go. I think it is the same problem if you buy a new one.
but there are those who open and make the arm, then the problem gets better.
08.05.2020 15:04 # 14
Eyup Duygun
Here I recommend getting the new one and having it in the service for not having any problems again.
08.05.2020 15:04 # 15
06ef
If [QUOTE = EmRaH] is such a problematic car, don't buy the car and don't stain it here. tickle up then [/ QUOTE]
We share problems, we also call it sellers, let's see the sound of a German car at the age of 7
08.05.2020 15:04 # 16
pug307_26
Even if it stays with the diesel pump, some of the endless problems of the automatic transmission endless clicks sounds from the interior, a lot of chronical problems followed by a comfortable but troubled vehicle compared to a known situation segment. Is a 110 hp motor or a vehicle burns this much? I respectfully remember the peugeot because of its excellent fuel consumption Alkış
pug307_26 2011-01-31 15:54:42
08.05.2020 15:04 # 17
I use 110 hp diesel 6-7 lt Göz Kırpma When we look at a car at the age of 7, there is a problem in every car. How did the previous one look at it? or how does the first person look? Thank God, I don't have any problems .. As an extra, I took the original 110 hp 30 tl of the gas, which had torn the gasket in the turbo hose, and I took it immediately. This stems from the high pressure in the turbo. If you look at your car, remember that the room looks
08.05.2020 15:04 # 18
06ef
My beautiful brother is in the right worm, I am the first owner, but the music system and the gear shifts to the transmission, when the signal arm breaks out once a week from the barrier, the person does not want to get back ...
08.05.2020 15:04 # 19
metin
[QUOTE = 06ef] [QUOTE = EmRaH] If it is such a problematic car, do not use the car and do not stain it here .. 7 years old, the problem with the diesel pump is going to get bored. tickle up then [/ QUOTE]
It is wrong to put 307 in the same shroud with the German car. because their costs are different and their quality is different. It is normal that the failures occur according to the price, because less quality materials are used compared to the German-made vehicles.
I think the comfort of the car you get is very good according to the price. If you want too, as you say your emrah, you give 5 thousand more, you get on the German goods, you don't need to stain 307.
You can also pay 5 thousand more for the German goods, you can pay it for 307 and get on smoothly.
08.05.2020 15:04 # 20
06ef
I do not understand what I wrote above, I think there is no smudging, I do not think that it can not be ridden for a long time at a cost of 5 thousand, I do not speak to other models, I do not know without knowing it, but I know 307 for 8 years and I speak accordingly ...
Page : / 3
