it sounds like something is rubbing !!!
08.05.2020 14:02 # 1
Hello, when my friends are walking from my car, it sounds as if something is rubbing. do you think friends can come from where this sound usually comes from the gearbox is not so much, but when you listen well, i can hear it from inside, my voice tool 307 1.6 disel waiting for your ideas, friends.
08.05.2020 14:02 # 2
CIHANGIR_DONMEZ
The axle balls may be knocking, I just changed, if the flywheel was ole, your vehicle would burn until it did not go away.
08.05.2020 14:02 # 3
tk ler for cvp. but why can such a sound come from the axle?
08.05.2020 14:02 # 4
hasimayaz
This sound can come from hundreds of points of the car where you need to make the circle a little smaller. With trial and error, the circle may become smaller. For example, while waiting or coming or walking? Pressing any pedal causes the sound to stop or increase. Does it change the situation when you are idle or in gear while walking ??
08.05.2020 14:02 # 5
Let's narrow the circle a little bit in low gear, but most of the full revolutions do not sound. After completing the crypt cycle, I showed it to a master again. tool 307.
08.05.2020 14:02 # 6
SelmanBeber
I had the same problem with my 206, as if a friction sound was coming from the engine, the sound was cut when the clutch pressed. the service said that the clutch is finished, had increased recently, we changed it, now there is no problem.
Do you cut the sound when you press the clutch? If it is not cut, I think it is not from the clutch. But you must definitely show the tool to the job ..
08.05.2020 14:02 # 7
hasimayaz
[QUOTE = ozgurkal A]
Axle head or bearing ?? it doesn't sound like that. it just knocks .. I think it's a bearing problem.
08.05.2020 14:02 # 8
[QUOTE = hasimayaz] [QUOTE = ozgurkal A]
first of all thanks. If there is a hitting sound from the axle head then cut off from the bearing. How much will anyone have a bidet information?
08.05.2020 14:02 # 9
hasimayaz
Only if the bearing changes, 40 lira or something .. If we say 30 lira workmanship 70- 80 TL for a single axle ..
